Author Topic: Rad fuse still blowing!  (Read 4062 times)
« on: September 26, 2008, 11:52:52 AM »
Old problem this.  My rad fuse keeps blowing.  I have now noticed that when it blows not only does the fan stop but the lights go out.  Turns out there is an extra relay for the lights wired into the rad fuse, should this be the case and could the extra load be blowing the fuse?
Ta
« Reply #1 on: September 26, 2008, 01:22:43 PM »
what extra lights are connected? If they are high load it will cause problems!
« Reply #2 on: September 26, 2008, 04:23:04 PM »
No extra lights, it the standard lights that are connected to it, I will post some pics later.
« Reply #3 on: September 26, 2008, 06:03:43 PM »
I found some older fuses, which are made from harder plastic, so they dont melt, and it has solved my problem. Dont think any lights should be connected to the fan fuse... should they?? :roll:
« Reply #4 on: September 28, 2008, 03:44:45 PM »
Here some pics, first shows wires soldered together, purple wire is from the rad fuse, red wire which is soldered to it is from the two extra relays for the headlights (shown in second pic).  The purple rad fan wire has a permanent 12v feed, so should this red wire be connected in this way or have it's own 12v feed fuse.  Can others check there wiring for as I think that this is the source of my problems.
« Reply #5 on: September 28, 2008, 04:21:28 PM »
First question is what do you mean by "from the two extra relays for the headlights"? why are there extra relays?
« Reply #6 on: September 28, 2008, 04:22:53 PM »
do you have spaces in your fuse box perhaps some one has relocated the relays because the fusebox contacts where banjax'ed.
also silly question does your rear wiper work? I seem to remember my rear wiper was seized when i got it and every time I switched it on it used to blow the fuse and then the cooling fan didnt switch on.. may or may not be connected but it was fine after I chucked the wiper in the bin....
« Reply #7 on: September 28, 2008, 04:46:00 PM »
There are extra relays because the UK requires that headlamps have additional DIM DIP ralays, where as on the continent it is not needed.  Rear wiper works fine.  It seems that when the fan goes and the headlamps are on the fuse blows.  It also look like someone has rewired it cos I have a wiring diagram for the DIM DIP circuit and the red wire should not exist.  So I am going to try to rewire according to diagram :???: .
« Reply #8 on: September 28, 2008, 05:21:18 PM »
Luckily when I bought the car it came with loads of history!  Looking through it I came across two invoices.  First one talks about repairing an electrical fault to the stop lamps and indicators.  Second one dated a few months later talks about fan fuse and radiator fan not working.  Hmmmm, could of found the problem!
« Reply #9 on: October 01, 2008, 06:44:25 PM »
It does look like a bodge job that was done on the dim dip circuit. I would disconnect all the extra wiring and start from scratch that and follow the wiring diagram. Make sure the relays are wired correctly it's easy to get these wired wrong  :shock:
« Reply #10 on: October 01, 2008, 09:19:02 PM »
Yep that's what I plan to do, this friday it should get done but I will keep you posted!
« Reply #11 on: October 01, 2008, 10:21:59 PM »
its amazing that for such a small car and so few wires theres so many problems !! i always found that most problems were caused by crushed or destroyed wiring around the passenger side front arch or under the rear bench of the bis . if you follow your route of taking all the foreign wiring away and re wiring i am sure you will succeed. good luck!
« Reply #12 on: October 02, 2008, 05:42:18 PM »
Quote
I have checked these places and it seems to be fine.
« Reply #13 on: October 04, 2008, 04:25:47 PM »
Just an update.  Looked at the fuse box and there should be two unused fuse locations.  For some reason the blank spaces have my headlamp wiring in them :smt017
« Reply #14 on: November 21, 2008, 06:26:32 PM »
WaHOOOO!  Shes back on the road! :D   After nearley 2 months off the road all my problems are sorted!  It seems the Dim-Dip had been wired into the rad fan fuse to draw 12v from, to correct an earlier fault I assume.  Any way, I have completley removed the Dim-Dip device and wired it up like the european versions and everything works great!  Took her out with a big smile on my face :D
Time will tell though if it has cured the blowing of the Rad fuse but fingers crossed.
