Author Topic: Looking at a Bis, Few questions???  (Read 12841 times)
jumpinjacks
    • http://www.jumpin-jacks.co.uk
« Reply #60 on: October 13, 2008, 12:26:15 AM »
Well I put it all back together today, done an oil change and bleed the cooling system ( front and back ) and took it for a drive.
These cars are good fun on the road aint they? lol. But the temperature guage still seems to go up a bit too high for my liking, the fan does kick in for about 20 seconds but it does it way to late imo. I think I am gonna wire up the fan to a switch or maybe the ignition and more than likely have it running all the time.
I put a hose through the pipes before fitting aswell to make sure they were clear. The pipe on the manifold that the temperature guage switch was on that goes to the front heater was very blocked so I cleared it through.
So where abouts on the temperature guage do most of your bis's run at?
Mine seems to go between the last 2 white lines before the red bit and sometimes more.
Also should the head be torqued down different because the head has been skimmed? We did it to 50NM just to make sure, what do you guys think, will this be ok?
Fiat 126 Bis Owner
« Reply #61 on: October 13, 2008, 05:44:56 AM »
Congrats for putting a nother Bambino on the roads..  :smt041  :smt041
you are right, these cars are really fun to drive, maintain, clean... well they are... :D  Hope you have much fun and laughs with it...   :wink:
as for the cooling, it really sounds a bit late for the fan to kick in at that stage, mine starts right about here...
it only went once near  the red line (i was overtaking a concrete mixer up a steep hill, going 50km/h in secon gear...  :D  :D ) and then when i stopped steam started coming out of the filler cap, it didnt over heat but it was really hot...
Try taking out the two stage switch on the radiator, and cleaning it, then see how it goes...
jumpinjacks
« Reply #62 on: October 13, 2008, 09:27:21 AM »
Ok thanks for that Gordan.
Where abouts does your car run on the guage from just just running around town and things? Is it the same place?
Because if it is then something must be wrong with mine, as it always stays way over half way.
Fiat 126 Bis Owner
« Reply #63 on: October 13, 2008, 03:31:34 PM »
Yes, the red line is the normal running position when driving around town, during summer, during winter, it hardly reaches even that... (this is roughly where the fan pops in....) :wink:
Just had another idea, try taking out the heat indicator thingy on the engine, and checking/cleaning/replacing that... perhaps its just showing the wrong temp?
jumpinjacks
« Reply #64 on: October 13, 2008, 08:06:25 PM »
I've wired the fan up to a switch now in the dashboard, and all's good. When it gets hot I just whack the switch on and then its ideal.
But it never runs at as low as you have shown on the picture. I thought I read somewhere that just over half ( 3 quarters ) is about right.
Fiat 126 Bis Owner
« Reply #65 on: October 13, 2008, 08:10:52 PM »
:smt102  But i never blew a head gasket, now did i?  :P  :P  :D
jumpinjacks
« Reply #66 on: October 13, 2008, 08:19:07 PM »
Fair enough
Fiat 126 Bis Owner
« Reply #67 on: October 13, 2008, 08:21:47 PM »
The manual states that the fan starts: 1st speed 96-100C° 2nd speed 101-105C°. So if you divide the scale on the instrument to 70,80,90 and so on, youll se that mine starts at the correct temp.
the red lines are 80,90,100,110,120 C°
« Reply #68 on: October 13, 2008, 08:25:37 PM »
« Reply #69 on: October 13, 2008, 08:33:32 PM »
glad you got it back together and working again, I usually put the blower on if starts getting hot but mines normally a bit hotter running the Cro_126bis's gets so I dont think youve much to worry about.
