Author Topic: Looking at a Bis, Few questions???  (Read 12841 times)
jumpinjacks
    • http://www.jumpin-jacks.co.uk
« Reply #45 on: October 06, 2008, 09:39:49 PM »
Carb has been removed. the 2 at the back of the engine are annoying, I have got one out ( the top one ) but wheres the other one?
Also in the manual it says that ( what to me looks like a thermostat housing ) is the actual thermostat. Is this right? If so then where would all the pipes go when you come to put it back together. It may sound stupid me asking but I don't know much about these cars.
Fiat 126 Bis Owner
« Reply #46 on: October 06, 2008, 10:06:38 PM »
I assume the thermostat should be inside- to be fair ive left mine in...if tis not there someone has beat you to it!
as for the exhaust its easier if you take the rear drivers side wheel off and jack the car up to get the other ones.
if you are  getting stuck take pics its easier for us to help then...
heres a couple of my "stripped" down pics if that helps-
jumpinjacks
« Reply #47 on: October 06, 2008, 10:46:33 PM »
Cheers for that Stuey. I'll have another go tomorrow.
I have also noticed an arm loose on the carb but not sure where it goes or what it does. I will post a picture tomorrow so that you know what I mean.
Fiat 126 Bis Owner
jumpinjacks
« Reply #48 on: October 07, 2008, 04:44:51 PM »
I got the head off and the gasket was stuck to the block, so dug at a corner and then it started to come off, but fell apart. So I guess that means that it was definatly knackered as it was so weak? Just gotta clean both the head and block now as theres still loads of bits of gaskets still left on it.
For skimming the head, would I have to take out all the studs, valves and things in it or would it be ok to leave them in?
Fiat 126 Bis Owner
jumpinjacks
« Reply #49 on: October 07, 2008, 07:55:01 PM »
Also forgot toask, while the head is off do you reckon I should tow it to my local garage and get it pressure tested?
Fiat 126 Bis Owner
« Reply #50 on: October 07, 2008, 08:21:03 PM »
good work!!
ok from the top-
1 loose arm is usually the choke- lever the clip breaks..(identifiable by the fact its poking out the top of the carb andand should connect with the choke butterflys
2 the gasket has been sujected to years of heating and cooling they just break down its normal
3 the valves can stay in situ (see my pics above) just  make sure that you clean the head meticulously prior  to refitting. not sure which studs need removing as from memory there arent any on the head face?
4 not sure what you mean by pressure testing if you want to test the cylinders you need the head in place if you mean testing the head then most good engine shops will do this
« Reply #51 on: October 07, 2008, 08:28:17 PM »
My you guys like to complicate things, why dont you just take that engine out?? its half an hours work, makes any other work on it simpler/faster, and for example you stuey could have  cleaned that tiny oil stain on your engine.... but when i think about it... you brits drink warm beer dont you? ah yes, that explains it all...   :D  :D  :D
jumpinjacks
« Reply #52 on: October 07, 2008, 08:30:30 PM »
Thanks Stu,
Dont think the arm is the choke arm, it is situated at the back of the carb ( when looking at it fitted ) I will try to get a pic to show what I mean.
The thing that worries me is that it overheated, even though it didn't have thermostat. Surely something else could be wrong?
Fiat 126 Bis Owner
« Reply #53 on: October 07, 2008, 08:34:27 PM »
Quote from: "jumpinjacks"
this my friend is starting to worry me... cos it means my gasket could be in grave danger... o-o.... :???:
does any of you lads know a simple way to check if the gasket had been replaced before, cos the previous owner told me it never was, but id like to check anyway...
« Reply #54 on: October 10, 2008, 09:14:00 AM »
Thanks Stu,
Just make sure your cooling fan and rad are working correctly and everything should be fine.  If one of these is shot it overheats and pop goes the gasket!  Also make sure you put good 50/50 antifreeze in and when you refill bleed the system at the front to get the air out.  Make sure your oil is at the right level as this aids cooling too.  Hope this helps!
jumpinjacks
« Reply #55 on: October 10, 2008, 10:32:54 AM »
My mechanic mate said to me that it is best to use just water in the older water cooled cars, as antifreeze was no good for it. Not sure though?
Fiat 126 Bis Owner
« Reply #56 on: October 10, 2008, 11:31:29 AM »
The manual states 50%antif. - 50% water...  :roll:
jumpinjacks
« Reply #57 on: October 10, 2008, 11:34:41 AM »
Quote from: "Cro_126Bis"
Thats what I thought aswell, so wasn't sure what to do  :roll:
Fiat 126 Bis Owner
« Reply #58 on: October 10, 2008, 12:24:30 PM »
Well think of it this way, wether you like it or not, or be it good for the engine or not, its going to get cold, so we have two options; put antifreeze in, or drain the system every day...  :shock:
TBH, i dont see any reason why antifreeze could be bad for the car, it pervents rust, it prevents freezing, only one thing thou, if its aggresive, it could damage an old radiator or something...
« Reply #59 on: October 10, 2008, 08:42:20 PM »
I think with some older cars (triumph tag is a good example) they type of antifreeze was important cos it could hurt the alloy block but most modern antifree is fairly harmless stuff (tastes like crap tho!)
