Author Topic: Over heating!!!!!!!!  (Read 2161 times)
kane
« on: September 01, 2008, 10:41:26 PM »
I have had a fiat 126 for around 6 months and for most of the time it was ok but recently i have had overheating problems. The water pressurised and came out when the cap was opened, I then managed to get a new cap with a pressure valve in it. This made no difference. I took the fan and rad out to have a look what condition they were in, these were fine. And last week to top it off the head went AGAIN. Would now like to do a complete engine rebuild where would i get shells, piston rings, pistons and all the other bits and peices i need to do this. PLEASE HELP[/b]
« Reply #1 on: September 01, 2008, 11:32:44 PM »
Hi Kane, you said that the head gasket has gone again, when it was last done did you have the head machined flat because they warp when they over heat? for a quick solution if you go to the home page scroll down to parts for sale, i think Phil still has alot of parts he may have a good bis engine, give him a ring. It will be quite expensive to do the rebuild you have suggested.
If it was mine i'd whip the head off have it pressure tested and if its O.K. have it machined flat, put it back with a copper gasket.
« Reply #2 on: September 02, 2008, 09:46:13 AM »
Take the thermostat out and throw it in the bin!
kane
« Reply #3 on: September 06, 2008, 10:28:40 PM »
hi, i had it machined and pressure tested and it was all ok. do you know if the rubber seels around the wet liners drop or if that would be the cause of the problem.
kane
« Reply #4 on: September 06, 2008, 10:30:06 PM »
oh and the thermostat went last time.
« Reply #5 on: September 07, 2008, 06:44:30 PM »
Is your fan coming on when it should.  Maybe the two stage switch is faulty causing the fan not to operate and then it will overheat.
« Reply #6 on: September 07, 2008, 07:10:36 PM »
The liners are pressed and sealed into the block i don't know of any rubber seals on the bis liners,
check to see if the liners have any hairline cracks in them, take the pistons to the bottom of the bore. this is noticable as its usually dark grey around the area
If they look O.K. then you can prepare to re-assemble the head to the block.
1.  Check that all the studs are at the same level.
2.  Clean all the threads that are rusted up on the end of the studs with a wire brush,
     ( This is very important because if you don't its possible that when you torque the head down it will tighten on the rusted threads instead of the cylinder head,
       and more so when the head has been machined flat)
3.  Clean out the threads on the domed cylinder head nuts. (I use wire wool)
4.  Check that the domed nuts go all the way down the stud threads  you shoulld be able to twist them all the way down with your fingers without them locking up,
     (a little copper slip helps, work them back and forth till they are free)
5.  Check with a steel rule that the liners are flat with the top of engine block.
6.  Clean the top of the engine block, remove any old gasket and dirt.
     (wash off with thinners to remove any oil/grease)
7.  Clean the face of the head with thinners
8.  The cylinder head gasket.  although they say you don't need to use gasket seal, i do for two reasons.
     (a) it seals any imperfections that the gasket can't.
     (b) It helps lubricate the cylinder head gasket when torqing down the head.
http://club126uk.co.uk/index.php?ind=downloads&op=entry_view&iden=9
I do appologise if you already know how to re-assenble the engine but it may help other 126 bis owners if they have to replace the head gasket.
