Author Topic: Hello & Issue  (Read 2514 times)
Si599
Hello & Issue
« on: August 31, 2008, 08:54:35 PM »
Hey Guys & Girls!
Im Si, im 22 and currently drive a 1.4 Fiat Stilo Active but i am currently doing a Classic Car Restoration course at college so got a few ideas and projects but the 126 has possibiltys.
Hope you are all well and happy. Me n a friend of mine have just bought a 126bis for 50quid... How good is that, well not very to be honest as we have an issue.
The battery was dead ish, but all the lights and things work so i connected it up to my car and tried firing her up. She is trying to start up and u can her here but its just not firing. We have been told that the Oil Pump is KaPut, but could the fuel pump be gone or what? It says it has a half tank of gas in it but.... i dunno, Any ideas?
Im really confused with it
Hello & Issue
« Reply #1 on: August 31, 2008, 11:15:28 PM »
Welcome to the forum, only thing i can suggest is you go through the basics, if the car has been stood for months/years it could be the petrol has gone off, this would need draining and fresh put in. check points, plugs, and static timing. check if you have a strong spark at the plugs. next take the petrol pipe of at the carb put it into a bottle and have someone turn the engine over a couple of times, if petrol is coming through then thats O.K. if its not its the pump, if it is, check the carb for dirt/sedament in the bottom of the float chamber and clean out,   Have Fun.  :)
http://club126uk.co.uk/index.php?ind=downloads&op=entry_view&iden=9
Hello & Issue
« Reply #2 on: September 01, 2008, 06:22:09 AM »
all the above, + my 2 pence worth is that the spring inside the fuel pump coorodes and stops the pump working....if the car has been sat, chances are the condensation in the engine has got to that spring.....
Si599
Hello & Issue
« Reply #3 on: September 01, 2008, 01:20:56 PM »
Hey,
Cheers for the information, the car was running till about 2/3months ago when it went into my mates garage. We had to tow it in as it wouldnt start. The fact that the Oil Pump doesnt work wont have anything to do with it not starting will it? Im not very good on the mecahnical side of things, im much more for the body work which leads me to another question. Where can i get body parts from, im compeltly new to the 126 game so all help would be real greatful. The car had a wee incident with a Audi A4 and the front right panel is ruined, i think the front bumper is re-pairable & same with the rear.
My other problem is that im 6ft3 and its difficult to sit in... but we will have to deal with that one.... lol!
Hello & Issue
« Reply #4 on: September 01, 2008, 03:21:43 PM »
welcome to the forum dont worry on the height thing I'm 6'2 and its a hoot, quick test for the petrol it to pour a little in the top of the carb and see if it fires, wont last long but at least it will show if its a fueling prob or not...
is there any fuel in the fuel filter?
subvert73
Hello & Issue
« Reply #5 on: September 01, 2008, 05:32:02 PM »
Hi Mate, welcome to the forum,
I just thought I should say it's probably not a good idea to even attempt to start the engine until you have replaced the oil pump.The knackered oil pump wont affect the engine starting but as the car has been sitting for months all the oil will have drained to the sump and the top of the engine will be fairly dry.
Just a short run or even just repeatedly turning the engine over while trying to start it could result in serious and permanent damage. :cry:
Steve.
Si599
Hello & Issue
« Reply #6 on: September 01, 2008, 05:33:19 PM »
Well this is a strange one mate, on ur picture of ur braided hoses ur fuel filter is on one of the two pipes sat next to each other, where as the one that is on the car we have got is on the pipe going from the fuel pump to the carb. Also there appears to be no fuel in the fuel filter.
Also Stuey your car is stunning and gives me plenty of ideas!
Hello & Issue
« Reply #7 on: September 01, 2008, 06:18:38 PM »
Hello, and welcome!  :smt006
The fuel filters were not standard, so people put them in where they please, at first i had one between the pump and the carb , then i took it off and put it before the pump, but this messed up my ignition as it took the pump some time to fill it up, so i now have no filter, and am doing just fine :DD
Hello & Issue
« Reply #8 on: September 01, 2008, 07:10:47 PM »
eeerrrr....i think some clarification is needed here? if the oil pump is knackered(highly unlikly) then you engine will be mostly completely buggered.......the reason it was parked will have been a shagged engine after running with no oil pressure......
i hope the person concerend meant the more common problem of failed fuel pump....
Maddog
Hello & Issue
« Reply #9 on: September 05, 2008, 12:05:08 AM »
as mentioned, if whoever told you the oil pump is fooked is correct, then your engine is rebuild material or scrap anyway,
quick test,
 with a fully charged battery, remove the plugs, then burl it over, it should easily turn over fast enough for the oil light to go out on the starter although it may take 30  secs to do so,
 if it doesnt then get some good jump leads and connect it to a normal size car with the engine running, leave it for 5 mins to fully boost the battery, get your mate to raise the revs in the jump car to 3k+ and try again, the starter will spin like it has never spun before and if your oil pump is good 90% of time the oil light will go out. if it still doesn't then you can remove the oil pressure switch and crank it for a second(put some paper down), oil will squirt out the hole.
or if you have easy access to a replacement engine and are not bothered about being able to rebuild yours, then as mentioned, check for a spark then just put some neat petrol or easy start down its throat and see if it goes
 :D
