Author Topic: Bleeding the cooling system on the BIS  (Read 2868 times)
« on: August 29, 2008, 09:03:10 AM »
Disaster struck yesterday.  Wen't work in the 126 and when I arrived steam was coming from the rear, I thought my kettle had boiled!  Thankfully a water pipe had split and all the water was gushing on to the engine, great hey!
So today I am replacing the pipe and refilling the water system.  However it has always confused me how to bleed the air out correctly.  I know you use the tap at the front but do yiou need to warm the engine first so the thermostat opens?  I did this last time but when I bled it I burnt my fingers on the hot water :cry:   So what is the correct procedure to bleed out the air!
« Reply #1 on: August 29, 2008, 11:37:54 AM »
Hers how i did it and so far it works (i don't have the thermostat so it might be different... )
first remove this screw from the rad (i think its this one... :P )
fill the water till it starts pouring out of that hole, then i close it. start the engine, and unscrew the front bleed pipe, turn the heating on and run the engine a bit faster to make the pump work faster, till the water starts running out constantly with no air. then just screw it back and hey presto its done!
now after typing all this down, i have a feeling it wont work for you thermostat guys.... LOL  :D
« Reply #2 on: August 29, 2008, 08:09:55 PM »
As gordon explained, but the car wants to be at full working temp.
« Reply #3 on: August 30, 2008, 08:39:02 AM »
Thanks for the advice, it is done.  I have replaced the smaller pipe in the pic:
Now I have the thermostat kit fitted so this pipe has been replaced B4.  I have measured it and it has a 10mm diameter, the only pipe I could get was 13mm.  I have fitted it and run the car to full operating temp and it does not leak but to you think it will be OK over time.
« Reply #5 on: August 30, 2008, 09:37:02 PM »
you can use 10mm black rubber fuel/air pipe they even do it in silicone (colours).
if you do a search on ebay theres plenty on there but it should be available at your local motor factor, with 13mm you are relying on the clip to seal the pipe.  :)
thebowman
« Reply #6 on: August 31, 2008, 12:14:16 PM »
Is that the themostat relocation kit you have fitted? if so where did you get it from as I am interested in fitting one myself
« Reply #7 on: August 31, 2008, 02:15:48 PM »
Yes it is the stat relocation kit, got it from Ricambio a long time ago, them may still sell it, give them a call.  It is around £120 though!
nrg19uk
erm
« Reply #8 on: August 31, 2008, 03:14:59 PM »
i have been looking into relocation kits and i came accross this http://www.eliseparts.com/shop/index.php?main_page=product_info&products_id=240 i was thinking of modifying the pipe work to suit, have you got any pictures of your kit? would it be possible to measure pipe sizes?
Neil gargaro
« Reply #9 on: August 31, 2008, 07:01:47 PM »
Here's a pic of the conversion from ricambio, it uses all the existing hoses so you will be able to measure your existing one's :)
