Author Topic: why wont she start?  (Read 1899 times)
elbisto
why wont she start?
« on: August 21, 2008, 02:01:05 PM »
help!
After having replaced the head gasket on my bis, I had her running for a couple of weeks, just around the yard and all was progressing ok, however she now refuses to turn over.
This wasnt an instant thing, there seemed to be a gradual reduction in power to turn the engine over, (for a few tries) and now it makes no noise at all when i try and start her.
I have tried the battery out of my daily runner cinquecento, but to no avail.
I have tried swapping the coil, but nothing. i noticed that the earth strap had come loose, so I reattached that today - could having started it with that not attached be the source of the problem? if so what could it have done?
I tried different (but old) HT leads, checked the connections on the LT leads - both seem to be plugged in ok. I have swapped over the relays with others, makes no difference. I checked the connections to the starter motor, the leads are all attached as they were when she was starting ok.
I have got somewhat suspect battery clamps, but it been the same for ages and has always started ok. they do not clamp on tight, but are definately attached. The battery has got plenty power to run all the electrics, so i dont think its the battery connections
 I had a look at the distributor, but all looks ok, however this could be one place to investigate further.
when I first started trying to turn her over, there was a definite click from the soleniod, but now that noise seems to have stopped too.
can any one suugest where to go from here?
phreak97
  • Niki!
why wont she start?
« Reply #1 on: August 21, 2008, 02:47:44 PM »
none of the ignition bits (coil, dizzy, spark plugs, or anything in between) have anything to do with turning the engine over.. your problem lies in the starter motor or surrounding electrics. i dont know how accessible the starter motor is on a bis, but you should first measure (with a multimeter) that there is 12v between where the thick wire goes into the starter motor, and the other big terminal with a little ground strap on it (there should be at 12 even with the key turned off) and then if there is, and if youre confident, you can try connecting 12v to where the thin wire goes in, if the key is off, then this will turn the engine over, but it will not start, so it's pretty safe. then if the engine does turn over this way, then it must be a problem with your ignition switch, or the thin wire between there and the starter motor. if it doesnt, then it's a problem with your starter motor or solenoid.
(you know what a starter motor looks like yeah?)
phreak97
elbisto
why wont she start?
« Reply #2 on: August 21, 2008, 05:39:39 PM »
starter is easy enough to locate, I have the cover off of it, and like i say, all the leads are still connected as they were when it started fine.
i think I have a multi meter in work somewhere, ill try what you suggest
Not too sure about all these starter related issues, so any pointers are a great help, . please excuse my lack of technical knowledge as I am a mere pushbike mechanic. I was following a books advice on starter issues, and it suggested to try all the things i tried, but its good to rule out a few possibilities.
all other advice gratefully received!
phreak97
  • Niki!
why wont she start?
« Reply #3 on: August 22, 2008, 09:24:05 AM »
dig out your multimeter, or buy a new one, theyre like $10 for a crappy one at any electronics store, itll do the job perfectly. go through the steps i posted, then let me know the results:) dont worry about your lack of knowledge, i didnt mean to come accross harsh.. two years ago i wouldnt have known any of this either.
phreak97
