Author Topic: Dodgy gear-selector  (Read 2586 times)
Dessie B
Dodgy gear-selector
« on: August 20, 2008, 01:58:37 PM »
Hi every-one,
    I'm having some trouble with my 126p I hope you can help me with,
  to get 3rd gear I have to push the gear stick down as if going for reverse,
  and stick wont go to the right enough to get reverse, I have an Auto-books
  and a Haynes manual and they show adjustment front to back, mine needs
  left to right, any-one come accross this or know to remedy it as pushing the
  car into spaces so I can drive out is no longer funny (to the person doin the
  shovin.) :cry:
   Thanks in advance, Dessie.
Dodgy gear-selector
« Reply #1 on: August 20, 2008, 03:11:17 PM »
I have had this problem before. You should try and adjust the linkage forward and back, this does also affect the side to side movement somehow.
Also you may have the same problem that I had, where the little plastic bushing that sits at the bottom of the gear stick (seating it in its housing) has perished, causing the gear stick to have more movement than it should, this consequently causes it to want to move too far from side to side. I don't think you can replace this part, but it is definitely worth trying the 2 adjusting bolts on the side of the heater tunnel that connect the gear shifter in place as this did solve my problem, I do have to adjust it relatively frequently as it does slip from time to time (probably reflective of my aggressive boy racer shifts!)
Dodgy gear-selector
« Reply #2 on: August 20, 2008, 06:33:29 PM »
I have the same problem have to "fake" it into 3rd then withdraw and it goes in on the second attempt....interested to see if any of the above works....will have a look!
Dodgy gear-selector
« Reply #3 on: August 20, 2008, 07:28:23 PM »
There is a plastic bush at the back of the gear lever assembly where the gear change link passes through & if that is worn it will give you jip !
Dessie B
Dodgy gear-selector
« Reply #4 on: August 21, 2008, 01:15:40 AM »
Thanks guys, I'll try to get a replacement from the Polish guys in work,
    and try the 2 bolts on the tunnel in the mean-time.
        Will let ye know how I get on, thanks again. :D
phreak97
  • Niki!
Dodgy gear-selector
« Reply #5 on: August 21, 2008, 02:56:22 PM »
could also be the linkage under the car.. if the two little bolts come loose it gives funky results.. last time i had everything out, i didnt do it up fully putting it back together and all the gears were wrong. (talking about the bit coming off the end of the gearbox)
i'd assume you could get similar results if the metal started to pull off the rubber, it would definately affect side to side movement.
just another idea.
phreak97
Dessie B
Dodgy gear-selector
« Reply #6 on: September 03, 2008, 10:43:01 PM »
Hi guys,
  I'v checked the flexible link between the gear-box and shifter rod, rubber in good shape(due to leaky gear-box seal) and both bolts tight, adjusted free play on clutch pedal to one inch as per Haynes, moved gear selector forward and aft in stages, removed the two bolts altogether and reset them but still cant get reverse, am I looking at a problem in the box itself?
  Thanks in advance, Dessie. :cry:
fightingtorque
Dodgy gear-selector
« Reply #7 on: September 04, 2008, 08:32:12 PM »
I have trouble getting third gear, I can see how to solve the problem, but I am not willing to cut my left leg off!
Dessie B
Dodgy gear-selector
« Reply #8 on: November 21, 2008, 02:14:26 PM »
Hi Guys,
  I'm finally getting back to work on my Malluch!
At this stage I have replaced the entire gear stick set-up.New gear-stick, guide rubber, tension spring and selector rod, new grease everywhere and although shifting is more positive, I still have to push down for third and cant get reverse. Please help as I miss driving my little Fiat.
 Many thanks,
Dessie
Dodgy gear-selector
« Reply #9 on: November 22, 2008, 09:54:41 AM »
if your still having agro it sounds like its in the box where you should be looking.
Dessie B
Re: Dodgy gear-selector
« Reply #10 on: November 26, 2008, 05:22:07 PM »
Thanks BIS13,
  I have price one in Katowice, Poland, coming in at 70E.
  Holding out for one with lower milage.
 Dessie B. ;)
phreak97
  • Niki!
« Reply #11 on: November 27, 2008, 01:00:09 AM »
the gearbox isnt that difficult to work on, you could try taking the top and front covers off and checking the selectors for damage or wear.
phreak97
Dessie B
« Reply #12 on: November 27, 2008, 05:04:58 PM »
I've asked the guys in work and apparently new selectors are no longer available, even in Poland. >:(
phreak97
  • Niki!
« Reply #13 on: November 27, 2008, 05:20:52 PM »
what are used ones worth to you? ::)
phreak97
