Author Topic: Alternator wiring 650cc aircooled - HELP!  (Read 18531 times)
jemima126
« on: August 14, 2008, 10:07:36 PM »
can anyone give me any directions on wiring the alternator on a 650 aircooled, put engine back in tonight but unsure if I put this bit together properly, also have constant indicator light from ignition??????????? :???:
« Reply #1 on: August 14, 2008, 10:59:44 PM »
Don't know if this will help jemima.
jemima126
« Reply #2 on: August 14, 2008, 11:17:32 PM »
cheers pete, think i'm on the right lines, managed to find something on the 500 forum, just need to solve the indicator light now and get it started!
phreak97
  • Niki!
« Reply #3 on: August 21, 2008, 03:13:03 PM »
i've recently learned alot about this, the 500 generator wiring doesnt help much.
the thick brown wire goes to the terminal with the nut on it, the brown wire coming out of the alternator plastic cover goes to any one of the three terminals that are all together (they are all connected together), the black-purple wire goes there too, as does the only one of the regulator wires that fits, the other regulator wire goes to the smaller terminal above the three.
if it is wired like this, and your battery light is still on when the engine is running, then there's a problem!
the battery light cannot be on if the alternator is running, which means your alternator is not running.. dont drive anywhere with your lights on or you wont make it home.
make sure nothing is shorted, and also make sure the ground strap is connected, though i doubt it would start if it wasnt.
good luck!
phreak97
jemima126
« Reply #4 on: August 21, 2008, 05:59:08 PM »
hi, I have all that done now so know the alternator is ok, I think it is the coil that has gone as cant get sufficient spark from the coil and cant start, no money for new coil at the moment but we may get a mobile auto electrician at some point to come and do some testing as we dont have the right tools, what a bummer she is so close to being finished!
phreak97
  • Niki!
« Reply #5 on: August 22, 2008, 09:25:49 AM »
wait, what problem are you having? the battery light wont go out till the engine is running.. and the alternator doesnt do anything till then either, if youre having starting troubles then that's a different section altogether.
if you tell us all your symptoms ill try to help as best i can:)
phreak97
