Author Topic: help! alternator or regulator problem?  (Read 1613 times)
phreak97
  • Niki!
« on: August 07, 2008, 04:39:50 PM »
i have just finished replacing the alternator in my car with a used one in unknown condition, and it does exactly the same thing, which is pretty much nothing. where do i measure to find out if it's the alternator or regulator which is faulty (either with the car running or not)? and given that i have another alternator out of the car, what do i measure to check if it's ok or not?
i havnt driven my niki in about two weeks, i'm desperate!
otherwise where can i get a new alternator that wont be hundreds of dollars? is there someone heading to poland (or there already) who could pick one up for me? maybe two if the price is right.
it's so much work to change though:(
phreak97
« Reply #1 on: August 07, 2008, 11:12:05 PM »
Its more likely to be the voltage regulator, the contacts burn and then it does'nt charge, if you swop the regulator with another one of your cars and see if that solves the problem.
phreak97
  • Niki!
« Reply #2 on: August 08, 2008, 03:26:01 AM »
mine's a late aircooled, it has a different regulator to that, but ill put in a known good regulator and see. i have already replaced the regulator, but i dont know if the one i put in was working or not.
phreak97
phreak97
  • Niki!
« Reply #3 on: August 09, 2008, 07:44:49 AM »
IT WAS THE LIGHT BULB!!
apparently if the light bulb in the dash doesnt work then the alternator never switches on.. pretty retarded design imo. oh well.. 8 or 10 hours work to reseat a light bulb isnt too bad:P
phreak97
