Author Topic: Bis Backfiring.....  (Read 2735 times)
Scouse_126
Bis Backfiring.....
« on: July 21, 2008, 06:38:56 AM »
Hi All,
Just a quick one really from the clueless fella from Liverpool, what causes my car to backfire? It doesn't do it when i start the car, mostly when im slowing down and on a few occasions when i have turned the engine off and got as far as getting out of the car to lock my door and boom. It can be quite entertaining as i travel around watching people dive for cover, but what damage could i be causing if any? I saw a little device on Ricambio's website that was supposedly to stop backfiring but where would it go? Hopefully someone can shed some light on the subject and help me out and maybe stop me taking a few years off my life expectancy as when it does it I come close to sh***ing myself  :wink:
Im happy to give anything a try, and you only learn by experience :lol:
Scouse
This is the thing on ricambio's site an anti backfire device???
Bis Backfiring.....
« Reply #1 on: July 21, 2008, 01:29:15 PM »
I would have thought either your timing is out (ie your spark is occuring during your exhaust cycle) or its over fueling , this might be that your running it on the choke? try getting the timing checked for starters and make sure the choke isnt left on too long.
Bis Backfiring.....
« Reply #2 on: July 21, 2008, 01:33:20 PM »
DK what causes it really, it happened to me twice when i pressed the gas pedal while trying to start it, and it didnt start so i went out and meddled with the ignition a little and BOOM!!! it just exploded out of the exaust, needless to say that i was scared to death, but it didnt do any damage...
ive heard of people having trouble turning the engine off if they put high-octane fuel in it, so you should check which fuel youre pouring in just in case..
Scouse_126
Bis Backfiring
« Reply #3 on: July 21, 2008, 10:08:32 PM »
Thanks Stuey, Thanks CroBis,
I'll get the timing checked out, it doesn't run for very long with the choke being used just the usual starting in the morning - very minimal
The fuel I use is unleaded normally from shell
Hopefully the timing just needs tweaking a little and it will be fine :wink:
lilgreencar
Bis Backfiring.....
« Reply #4 on: July 22, 2008, 08:49:48 AM »
Here is some info on back-firing:
http://en.wikipedia.org/wiki/Back-fire
With the timing advanced too far, mine would backfire more, and also would be very hard to start when warm (would start fine when cold...).
The gizmo in the Ricambi photo above is a flame trap that goes in the tube connecting the crankcase breather tube to the air filter. This will not help stop your backfiring problems. But, it would help arrest the flame that goes traveling up the breather tube during an intake back-fire from setting your engine compartment on fire!
Bis Backfiring.....
« Reply #5 on: July 22, 2008, 07:01:07 PM »
i normally find they are placed in the exit tube of the rocker cover before the breather pipe
lilgreencar
Bis Backfiring.....
« Reply #6 on: July 22, 2008, 07:05:26 PM »
Quote from: "bis13"
Yeah, that's where mine is too... The diagram above is from my Fiat 500 Haynes manual.
Bis Backfiring.....
« Reply #7 on: July 24, 2008, 11:09:02 AM »
Try changing plugs.
When the ignition is off it cannot fire but sometimes when the plugs are knackered they can cause ignition after the ignition switch is turned-off.
Maybe they get too hot or something.
Bis Backfiring.....
« Reply #8 on: July 25, 2008, 12:53:32 PM »
right if its still backfiring that means you are either too advance in the timing and then the exhaust valves are opening as you ignite the fuel.or you are running too rich and the excess is igniting as it builds up in the exhaust . it could be your valve adjustments might also need adjustment.does the engine run on after you have turned the engine off?
re reading your post tells me that you are getting a build up of unburnt petrol after you have  turned the motor off ,its too rich in the mixture.
Scouse_126
Bis Backfiring
« Reply #9 on: July 25, 2008, 04:21:51 PM »
Hi Bis13,
Im a complete novice when it comes to the car and everything Ive done so far has been explained in steps just ask Pete_126!!! :D
I haven't replaced the plugs as of yet but I am going to, the car doesn't run on when the ignition has been turned off, just on occassions it will backfire, not everytime I get out of it  :oops:
Sometimes aswell when I have been driving for a bit and I shift down in the gears when slowing down now and again it will backfire, although its quite amusing watching people duck and run for cover...hee hee
So you are probably right in what you say about valve adjustment???advanced timing??? the mixture??? and there being an excess of petrol in the exhaust.
What should I do or what do I need to do to sort it out :???:
Any advice is greatly appreciated.....
Cheers Scouse
Ive sent a PM to you aswell :D
Bis Backfiring.....
« Reply #10 on: July 25, 2008, 04:28:21 PM »
Make sure your contact breaker points gap is set correct  before doing the ignition timing.
It may be a simple matter of just setting the points
Scouse_126
Bis Backfiring
« Reply #11 on: July 25, 2008, 04:32:59 PM »
Cheers Chris, Ive just installed an Electronic Ignition thanks to Pete, and I am in the process of replacing the points but will check to make sure all is well
Scouse
