Author Topic: bad electrical issue  (Read 2751 times)
phreak97
  • Niki!
« on: July 20, 2008, 04:01:33 PM »
i have a 1990 aircooled with regulated wipers and all that, and it keeps blowing the hell out of the fuse that runs the wipers, indicators, fuel gauge, brake lights (i think) etc.. is there a common place where i should look for a short? it seems to only blow it after i start the engine.. but i cant be sure of that, it might just be some bare wire that rattles up against some metal somewhere when the engine starts, it might not be directly related. i also thought maybe it does it when i put my foot on the brake, cos i do that when i start it.. i only had two fuses, so i didnt get much chance to fault find.
anyone know a common place for wire breaks such as this one?
i'd really love a wiring diagram if anyone has one.. i had one for an old mk1 aircooled, which probably would have helped, but i dont seem to have it anymore at all:(
phreak97
Re: bad electrical issue
« Reply #1 on: July 20, 2008, 09:31:23 PM »
Quote from: "phreak97"
checkout the downloads section
 :D
« Reply #2 on: July 20, 2008, 11:11:21 PM »
is it the front or rear wiper that isnt playing?
phreak97
  • Niki!
« Reply #3 on: July 21, 2008, 12:45:47 AM »
theres a rear wiper?
it's everything.. theres a short on the line somewhere, it stops my wipers (theres no rear.. aircooled), my indicators, my fuel gauge, plus maybe some other stuff, so the fault could be anywhere.
phreak97
« Reply #4 on: July 21, 2008, 12:45:47 AM »
Quote from: "stuey"
erm, the aircooled doesnt have rear wipers...  :cool:
« Reply #5 on: July 21, 2008, 12:47:28 AM »
id check and replace the relays first, dk about the aircooleds, but the bis has some really low quality ones...  :???:
phreak97
  • Niki!
« Reply #6 on: July 21, 2008, 01:15:27 AM »
the only one i havnt checked is the wiper relay.. ill check that out then.
i wish there was an easy way to test it without going through a heap of fuses..
phreak97
phreak97
  • Niki!
« Reply #7 on: July 21, 2008, 06:47:45 AM »
it was the reverse light switch, the fuse blew thoroughly as soon as i put it in reverse.. i tried plugging a bit of wire between the connectors and the lights came on and the fuse stayed happy, then measured the switch, and it's got about 100 ohms between it and ground when it's on, so ill see if i can dig out a new one.
edit:
all done! i had another switch in my pile of 126 junk..
turns out i had problems with my lights aswel, one of the spade connectors had broken off underneath my fuse box, and one of the connectors that plug onto the rear lights was mangled.. but it's fixed for now, until next time the connectors die.
phreak97
« Reply #8 on: July 21, 2008, 01:30:55 PM »
Quote from: "Cro_126Bis"
Quote from: "stuey"
my bad must learn to read before answering...... I had a problem with my bis cos the rear wiper was seized.. sounded familiar... :oops:
« Reply #9 on: July 21, 2008, 01:35:53 PM »
Quote from: "stuey"
Quote from: "stuey"
 :smt018  :smt018  :smt003  :smt003
p.s. wish i had rear wipers....  :cry:  :cry:
phreak97
  • Niki!
« Reply #10 on: July 23, 2008, 09:58:08 AM »
bloody hell.. third problem in about two weeks.. im not making a new thread cos i fixed it already, but yesterday my speedo started cicking then throughout the journey progressed on to an extremely loud whining (drowning out all other sounds including the engine and even the buzzer i put in to let me know my indicators are on. very loud.). i ended up just changing the whole instrument cluster over, so i've gained 5000kms on the odometer.
phreak97
