Author Topic: Removing the carb  (Read 1419 times)
James
Removing the carb
« on: July 19, 2008, 01:31:09 PM »
we need to remove the carb to get at the cylinder head. we have already successfully removed the rocker cover. from what i can see, this should come off after we've removed the two bolts, but it wont move even with a lot of gentle persuasion. :)
is there anything else which needs to be undone, or is that it.
your help is much appreciated.
thanksx
looking grimey in the pictures, didnt want to get oil on any new clothes...
these are images showing what has been removed, click to enlarge pictures.
Removing the carb
« Reply #1 on: July 19, 2008, 06:58:29 PM »
hi you need to remove the carb from the intake manifold as there is a third bolt inside the manifold itself
James
Removing the carb
« Reply #2 on: July 20, 2008, 09:28:45 PM »
I suspected that was the case.
what is the direct route to removing the carb from the manifold, which bolts? as we did try to remove it from the int' manifold but to no avail.
thanks
Removing the carb
« Reply #3 on: July 20, 2008, 10:39:06 PM »
Hi James you'll need a 10mm open ended spanner to undo the the last nut at the rear RHS thats difficult to see, if you have a small mirror that will help you locate it, as mick pointed out the last two head bolts are under the inlet manifold, see piccy. click to enlarge
something else to be aware of is make sure when you put the rocker shaft back, make sure the oil feed pipe is seated in the block and rocker shaft.  :)
