Author Topic: thermostat  (Read 4040 times)
ryhan_pea
thermostat
« on: July 18, 2008, 09:28:13 AM »
So i've got my bis running after head gasket replacement.  Yesterday, I refilled the cooling system, started her up, got the engine nice and warm but the thermostat wouldnt open.  The top hose coming from the temperature sender unit to the top of the rad was extremely hot, whilst the bottom one going to the the thermostat was freezing.  This is a new thermostat aswell, I've had it on there about a month.
I took the thermostat off and just heated it up in some water, with a thermometer in the water.  It only started to slightly open at around 94 C and was properly open about 98 C.
ryhan_pea
thermostat
« Reply #1 on: July 18, 2008, 10:22:38 AM »
Answered my own question. I tested the thermostat a few more times this time feeding the probe through the one o fthe side inlets.  This gavea more accurate reading and it opened at 88, then 89, then89 again.
I'm going to put it back on now and see what happens.  The heater wasnt working yesterday so i think there was an air block preventing the thermostat from reaching a high enough temperature. hopefully thats all it is.
thermostat
« Reply #2 on: July 18, 2008, 10:01:53 PM »
Did you bleed the heater system? its the little tube on top of the heater in the front boot.
ryhan_pea
thermostat
« Reply #3 on: July 18, 2008, 10:10:36 PM »
yep and its now working! thermostat opens fine, it wasnt pening because of he air block at the heater system stopping the hot water from circulating through the thermostat.
thermostat
« Reply #4 on: July 18, 2008, 10:29:27 PM »
There used to be a similar problem on one of my old cars a rover v8. The problem was an air lock problem in the thermostat housing, and if you have an air lock at the thermostat it will not open and therefore the engine overheats.
Perhaps this is a similar problem too the dreaded Bis overheating problems?
Strange that Bis owners who remove the thermostat seem not to have the overheating problems!
thermostat
« Reply #5 on: July 19, 2008, 07:07:49 PM »
its a very simple fix but the cause of major headaches
loose the thermostat for an easy life!!
phreak97
  • Niki!
thermostat
« Reply #6 on: July 20, 2008, 04:49:32 PM »
so many cars have thermostat problems, and it seems like most of them dont need it in at all.. Why didnt they save their money and just put them in cars heading for freezing climates? Im thinking of removing the thermostat in my aircooled. though its a different system, i have a feeling mines failing too.. Its hard to judge though.
phreak97
thebowman
thermostat
« Reply #7 on: July 20, 2008, 07:56:08 PM »
I'm planning on a 70ish mile motorway journey in my 126 next weekend, and am worried about this overheating  and head gasket blowing problem happening. Does removing the thermostat decrease the chance of this happening, and if so is it as easy as opening the thermostat housing and removing the thermostat?
Cheers All
thermostat
« Reply #8 on: July 20, 2008, 09:22:30 PM »
Dont know how to take it out, mines out when i bought it, but it will surely stop the gasket from blowing. the only thing is it takes a little longer for the engine to heat up, but this shouldnt be a problem during the summer. and ive heard of people puttin them back on during the winter.
thermostat
« Reply #9 on: July 21, 2008, 03:48:44 PM »
its very simple to remove so if you wish to do so then go ahead , its a shame the bis makes there owners stress so much.
thermostat
« Reply #10 on: July 21, 2008, 04:31:30 PM »
The ammount of joy greatly outweighs the ammount of stress, so its worth it...  :D  :D
ryhan_pea
thermostat
« Reply #11 on: July 21, 2008, 06:25:21 PM »
thebowman, i have the newly designed stat, and yes it is as easy as taking off the housing and removing the stat.  The older one has a clip holding it in, so may be a bit more difficult especially if its a bit corroded.
i think i'm going to remove the stat for summer, just while i'm doing the first few hundered miles with the new gasket.
thermostat
« Reply #12 on: July 21, 2008, 06:27:16 PM »
Quote from: "phreak97"
the aircolled has a thermostat?? what for?? :smt017  :smt017
phreak97
  • Niki!
thermostat
« Reply #13 on: July 22, 2008, 02:33:33 AM »
it's connected to a little flap under the right side of the engine's metal housing thing.. it opens and closes depending on the heat of the engine.. when it's closed the airflow is limited and the engine heats up quicker.. i suspect mine doesnt open properly though.
phreak97
thermostat
« Reply #14 on: July 22, 2008, 12:55:34 PM »
ooh.. cool :cool:
