Author Topic: rocker cover  (Read 2358 times)
elbisto
rocker cover
« on: July 16, 2008, 03:11:43 PM »
can anyone help?
I have just replced the head gasket on my bis, and am setting it up to go back on the road. The problem im having is related to the rocker cover. I started it up and the was a big oil leak coming from the lower half of the rocker cover. I removed it, straightened it a bit in the vice, and put it back on much tighter.
Now however, the car refuses to start. Its as if there is no spark , the engine is turning over, but will not come to life. the only thing that ive done differently is tighten up the rocker cover. Spark plugs are connected ok, and i cant figure it out.
Any Suggestions?
phreak97
  • Niki!
rocker cover
« Reply #1 on: July 17, 2008, 12:27:35 AM »
dunno about the bis, but in the aircooled the rocker cover very easily bends when you tighten the nuts too much, the top can bend in and press the valves in so you dont get any compression. if you tightened the nuts until they got stiff hen this is probably what you've done. if so, youll have to bash it back out again.
good luck:)
phreak97
rocker cover
« Reply #2 on: July 17, 2008, 01:46:58 PM »
try removing a spark plug leave it connected to the lead and earth the tip and hold onto the plug with some pliers and get someone else to turn it over (or get a remote starter) and see if it sparks at least youll know if the ignition is at fault then...
elbisto
rocker cover
« Reply #3 on: July 17, 2008, 06:13:49 PM »
problem solved:)
it was overtightening of the rocker cover nuts, when i took it back off, it turned out that the rocker arm had been bashing off the inside of the cover, and been knocked off of all the rods.
I have bashed it back into shape, and repsotioned the arm, and bingo, she started first time.
New problem is the heat of the exhaust. Its is red hot. I seem to remember it being a bit warm, but its positively smoking now. The fabric pipes which should be attached to the exhaust manifold have never been attached since i bought the car, and ive always been a bit concerned by it, but never had this sort of problem before.
How hot should the exhaust be, and how can i go about sorting this, as the fabric pipes are shredded. Any reason that it should be so much hotter, now that ive had the engine out, exhaust off etc?
phreak97
  • Niki!
rocker cover
« Reply #4 on: July 18, 2008, 01:32:16 PM »
yay, i was right:D
i've never heard of hot exhaust as a fault.. most people wouldnt notice..
you should reset all the valve clearances to what it says in the manual, since thats what you were playing with..
otherwise make sure your oil and coolant levels are good, and your thermostat isnt broken.. (though i dont know how to check it)
its the engine heat that you should be worried about.
phreak97
elbisto
rocker cover
« Reply #5 on: July 18, 2008, 03:52:48 PM »
yeah your probably right, i should have bigger things to worry about, all the coolant and oil levels are good so should be ok
On trying it again, although the exhaust is hot, it looks worse cos its still got some of the residual oil from the rocker cover leak on it, I have given it a good clean up with some degreaser and will try it again later once the battery is properly charged.
Then its only a new choke cable and fix the throttle cable spring a little and well be back on the road. Still interested in the thermostat relocation kit if anyone has done one and can advise? -  dont fancy doing the head gasket again in a hurry
phreak97
  • Niki!
rocker cover
« Reply #6 on: July 18, 2008, 05:14:33 PM »
you can pretty safely just take the thermostat out and survive without it.. just means you have to have the choke up a bit longer on cold mornings. saves overheating though.
phreak97
elbisto
rocker cover
« Reply #7 on: July 18, 2008, 08:55:16 PM »
sounds good to me
i notice that you live in australia however, do you have the same sort of cold mornings we get in the less exotic climes of central scotland?:)
phreak97
  • Niki!
rocker cover
« Reply #8 on: July 19, 2008, 11:48:25 AM »
no, but we dont have the bis either, it was a uk member who first came up with the idea of removing the thermostat entirely.
phreak97
phreak97
  • Niki!
rocker cover
« Reply #9 on: July 28, 2008, 03:41:40 PM »
i took my rocker cover off the other day and mine had been hitting too :P
i hadnt noticed any problems though.
phreak97
