Author Topic: Temperature Problem  (Read 1451 times)
gdore
Temperature Problem
« on: July 10, 2008, 07:22:18 PM »
I have just bought a 126 Bis and when I am driving the temperature gauge
goes up to the 3/4 way and then goes  down to the 1/2 mark when the fan comes on. Is this a fualty stat or normal. Also should you fill the water up with just antifreeze. Can anyone recomend a good oil
Temperature Problem
« Reply #1 on: July 11, 2008, 06:46:34 PM »
This is normal for the stat goes up to 3/4 and the fan comes on and pushes it to 1/2 way.  Put the heater swtiches to hot all the time and this helps with the cooling.
Drain the water system.  Get good antifreeze and mix it 50/50 with de ironized water and refill!
For oil check your users manual.
Temperature Problem
« Reply #2 on: July 13, 2008, 11:34:58 PM »
use  halfods classic oil it does the job ok
