Author Topic: Alloy Wheel Refurbishment and Tyre Choice  (Read 4271 times)
Milky
« on: September 11, 2005, 07:53:31 PM »
Hi Folks
Got hold of a set of X1/9 Cromodora alloys, which need refurbishing. Any one got any contacts in this field?
I test fitted the wheels on my BIS, and they fill the rear arches beautifully, but are a bit too big for the front.
The 2 that have tyres, the tyres are shot, and I can't read what size they are.
The wheels are 5J x 13, and I could do with some advice on what size tyres to fit.
I will post some pictures on my website in a day or so of the wheels on the back.
Mily
slater
    • http://www.retro-rides.com
« Reply #1 on: September 12, 2005, 10:28:04 PM »
Humm no bigger than 165 with nice low profile i would say. If you have problems with tyres fouling the arches then you can stretch tyres and use lower profile to help get around the problem.
Milky
« Reply #2 on: September 12, 2005, 11:07:31 PM »
Slater
Just had a look, and the tyres on the 2 wheels are 165/70R13, and they foul on the front.
The original tyres are 135/70R13.
Any ideas on what profile 165's would be OK?
I would like to keep the 165/70/R13 on the rear, as they fill the arches perfect.
It would mean carrying a tin of that puncture foam, rather than 2 spare wheels!!
I am a little concerned with the width as well, catching when the wheels are in full lock.
I may try and get a couple of part worn tyres fitted just as a test.
Is there some sort of a formula for calculating the profile of the tyre to make it clear.
Milky
« Reply #3 on: September 12, 2005, 11:37:59 PM »
I think the profile ratio is a calculated like this?
example: 165/70x13
165 is the tyre width in mm
70 is the tyre profile in % of the width, so it's 70% of 165 mm
13 is the tyre diameter in good old inches
I cannot guarantee this is correct, just going off memory
« Reply #4 on: September 13, 2005, 11:32:49 AM »
i have 5 1/2 j x 13 CD 11 cromodoras on my 650 running 165/55 profile,they JUST touch on the lower part of the front arch SOMETIMES,im living with it..................dunno whats gna happen when it gets lowered though :roll:
ALSO,the same profile/width sized tyre can be different between manufactures,the way the shoulder of the tyre is designed can give you more clearence for the same size tyre
« Reply #5 on: September 13, 2005, 02:56:18 PM »
Dave let us have a pic of your alloys in action! Please  :roll:
I hav just had fun and games recently with buying tyres, not many companys produce the orginal tyres now for our sizes.
I dont think that rubbing/knocking is a problem, my m8ty has a golf gti hes just had it lowered and occaisionaly over certain rough country road bumps it scrapes.
« Reply #6 on: September 13, 2005, 09:35:05 PM »
for re-furbing try www.aerocoat.net as for tyres im running 175.50.13's (mini tuners sell these)
slater
« Reply #7 on: September 13, 2005, 10:02:06 PM »
Yeh thats a good tip. look at Minis they have simlar problems and simlar sized wheels :)
