Author Topic: Head Gasket-help please  (Read 2880 times)
davesmall
« on: July 06, 2008, 09:38:17 PM »
Can anyone explain the deal with the blowing head gasket. I have got just got a car that has done only 7000 miles from new. traveled to brighton and back (60 miles round trip!) and didnt do over 60mph and the head gasket blow. I get the impression this is a common problem. Is there anything I can do to overcome this in the future? Am i doing anything wrong???
cheers for any comments or suggestions
Dave
« Reply #1 on: July 06, 2008, 11:01:15 PM »
to fix - remove the head get it skimmed and refit
to prevent in future- get a thermostat relocation kit from ricambi
its nothing you have done its just poor design from the factory.... :wink:
« Reply #2 on: July 07, 2008, 06:45:59 PM »
you do not state whether it is a bis or aircooled 126 , if its a bis the overheating is a design problem within the engine the thermostat is too far away and it fails easily, relocate the thermostat using a kit , remove the cylinder head and check to see if its warped if so reskim and replace , you can get copper gaskets that are thicker you might need one if you reskim depends on how much .
 the compression will alter slightly and if you have blown the gasket once just skimming and replacing with a stock gasket might only increase the chances of a future failiure
.if its an aircooled 126 then the reality is you have overrevved the poor engine or its a very old gasket and has just given up
elbisto
« Reply #3 on: July 08, 2008, 11:37:46 PM »
i have just changed the head gasket on my bis, not got her running again yet , but with another battery tomorrow morning, fingers crossed!
im just wondering how much of a job the thermostat relocation kit is? do i need to drop the engine out again? i don't like the sound of the head going again and if its an easy conversion, then ill definately do it, probably would anyway but can anyone explain where the relocated thermo goes just to give me a heads up?
cheers
James
« Reply #4 on: July 10, 2008, 10:01:50 PM »
Is it completely necessary to drop the engine or take of panels to fix a bis headgasket?
i really need to get mine done. at least ive got the part.
been researching all that needs to be done hopefully will be soon.
i should really get some guidance though or at least a walkthrough on the internet.
anyone got a step by step guide?
elbisto
« Reply #5 on: July 11, 2008, 12:28:42 AM »
i have just done mine james, took me a wee while, but i drove her yesterday, sounded sweet! i think its possible to do the head gasket in situ, but its easier to work on with the engine where you can get at it. if youve never done anything like this before, like i hadnt, its a bit more complicated than i first imagined, and I had some good advice from a mechanic friend which was invaluable.
theres a step by step guide to dropiing out the engine in the bis workshop manual ( i think you can download one, the link is on this site) , just drop it out onto a trolley jack , i took the gearbox out too, but you can leave that in, the workshop manual takes the gearbox out to, so easier to follow if you do that. theres a few fiddly bits when removing the engine but its quite straightforward, just tircky the first time if your not too sure where everything is, the pics in the manual arent very clear sometimes and words are minimal.
mark where all the cables, and hoses go, and unscrew all the right bits. make sure you keep all the nuts and bolts, washers etc, mark them carfully so you know where to put them when putting it all back together. Then you can drop the engine out. you need to remove the back panel of the car to do this, but its just all bolted on., so comes off pretty simply. make sure the jack is securely underneath the block before you ondo the engine mounting bolt. once its out youll need to reomve the exhaust manifold, rocker cover, and carb,  remove the rocker arm (its all at the right hand side, as you look from the rear) ato get at all the cylinder head bolts. undo them all and slide off the cylinder head, , and remove the offending blown gasket.give it a light smooth scrape with a scraper, not sandpaper, to get rid of any stuck gasket, from both sides, but carfeul not to scratch or gouge at it. i took the head to get skimmed at an engine services specialist, definately best to get this done, cost about 40 quid
when your ready to put it all back together, get a hold of a torque wrench, and feeler guages, and put the new gasket into place. follw the correct tightening order of the head bolts, and only tighten them to the specified torque in the manual, or i think theres another one elsewhere on this sight with different tightening instructions, - search for bis cylinder head torques in the forum.
put all the rest back on, youll need new gasket for the carb, and exhaust ,and rocker cover and when youve put the rocket arm back on, set the valve clearances using the feeler guages.
then reverse the engine removal process, connect it all back up, fire her up with the spark plugs out, to make sure it runs ok if it all sounds good, put the spark plugs in and your good to go.
hpe this is of some use, i found it quite tricky to find a good walkthrough, but it was quite a logical process, one step at a time. give us a shout if any of this is a bit unclear
« Reply #6 on: July 11, 2008, 09:57:28 AM »
its not necessary to drop the engine but i would remove the back panel (aftet supporting the engine) as from experience this makes the job alot easier..
James
« Reply #7 on: July 12, 2008, 03:21:19 PM »
though making the job harder, is it possible to not drop or remove the panel? its just the area around the panel is pretty rusted and the bolts are seized good. and im too scared to remove the engine although my mechanic friend will probably have no trouble with it.
James
« Reply #8 on: July 15, 2008, 03:49:32 PM »
started going at it today with a friend of mine. removed exhaust, rocker cover and undone bolts on the carb but it doesnt seem to want to come off. which bolts need to be taken off before the carb can be removed?
« Reply #9 on: July 18, 2008, 10:56:00 AM »
Cheapest thermostat cnversion is to chuck the thermostat in the bin!
Honestly mine has run for years without one, I only figured it out when I took the housing off and found nothing.
« Reply #10 on: July 18, 2008, 11:35:20 AM »
so another bis without a thermostat eh? cool, as i said many times before, mines never blown the head g. ever. so just take it out!
