Author Topic: MOT'd!  (Read 1954 times)
fightingtorque
MOT'd!
« on: June 27, 2008, 07:15:24 PM »
The bis I bought a fortnight ago turned out to have a bent MOT certificate, some corrosion in the spare wheel well and a duff fuel pump.
A quick bit of MIG later, bit of fiddling to get all the lights working etc. and the local garage has just handed me the coveted (and genuine) VT20 MOT certificate.
Ahead lies a bit of baseline work on the carburettor, some added instrumentation ( wideband lambda sensor, crank pickup, data logging ) and then it'll be time to test the engine management on it.
I'm on a J plate and in blue.  Will be running around the Hingham/ Hethel / Wymondham area, hope to see some of you on the way.
Cheers,
Gav
MOT'd!
« Reply #1 on: June 28, 2008, 04:12:35 PM »
well done on the mot-theres a retro rides meet at the angel pub at larling (snetterton) on weds night from 20:30 onwards bring it down and meet some other petrol heads they will be pleased to meet you- I'll be there and might even buy you a beer!
fightingtorque
MOT'd!
« Reply #2 on: June 30, 2008, 08:49:02 PM »
I'll try to get along there.
Gav
MOT'd!
« Reply #3 on: July 01, 2008, 11:25:25 AM »
would be good to meet you and see the basis for this fuel injection system...  :wink:
Normansinjunstevas
MOT'd!
« Reply #4 on: July 01, 2008, 04:00:04 PM »
Gavin, my son.
How did you find out the MOT was hookey? Was it trouble getting the road tax disc online, or that nasty corrosion that spelt it out?
Respect....Norman.
fightingtorque
MOT'd!
« Reply #5 on: July 01, 2008, 09:34:19 PM »
You can look up the MOT's on the internet - VOSA have their own website.  I was concerned about the whole car because the fuel pump issue didn't tie in with everything else said.  Also the tax disc was handwritten, all my other ones are computer printed.
Tax turned out to be fine (you can look that up as well on DVLA's site, but the MOT was non-existent.  Same garage on the sheet as had done it the previous year but no records of a pass or fail, same thing when I phoned the actual garage.  The form appears genuine, I think sometimes the blanks get stolen - that's what I learned from watching shameless on the TV anyway.
cheers,
Gav
MOT'd!
« Reply #6 on: July 03, 2008, 09:46:38 AM »
Quote from: "stuey"
and make it he did!! twas a good night-
MOT'd!
« Reply #7 on: July 03, 2008, 12:25:54 PM »
Beautiful pic, really...
and thats a nice Å koda in the back, Rapid if im not mistaken, been trying to locate one for a while now....
fightingtorque
MOT'd!
« Reply #8 on: July 03, 2008, 12:26:54 PM »
This is the throttle body injection system we are currently testing on a motorcycle engine (about 250cc).  The ECU is contained in the yellow box, the injectors are inside the chamber on the top, and they combine the function of pumping, metering and injecting the fuel so there is no need for an electric fuel pump.  Fuel supply is either gravity fed or if the tank is below the engine we generally use a small diaphragm pump driven by crankcase pressure pulses, which are the same pumps used on larger lawnmower engines (ride on mowers etc, 20hp plus).
The ECU can also control up to two ignition coils (with external driver transistors).
I will get some better and bigger pictures when I get it on the car, probably won't be until August as I have some business travel and stuff.  Until then I am just enjoying running the car.
