Author Topic: corrosion in the spare wheel well  (Read 2037 times)
fightingtorque
« on: June 22, 2008, 09:24:09 PM »
Hi Guys,
I've got some corrosion in the spare wheel well, probably because of battery leaks in the past (I just bought this car).  It's been overplated but there is still some rust.  Is this location key for the MOT?  It's quite close to the front suspension.
Other than that I've been crawling round underneath and its really solid.
Cheers,
Gav
« Reply #1 on: June 22, 2008, 10:11:29 PM »
ive never heard of a car failing because of rot in this area , its a water holder at this point as the little drain holes get clogged up and most owners fail to look into the well until the damage is done.
« Reply #2 on: June 23, 2008, 06:00:06 PM »
mine did! its considered structural....
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
« Reply #3 on: June 23, 2008, 06:13:51 PM »
Ours failed on this also. Any excessive rust within 30cm of suspension or steering components will fail an MOT. In this case, the spare wheel well, although not physically connected to, is within 30cm of the steering rods. If the steering components were located so that they connected to the rear of the front wheels rather than the front, they would be far enough away from the wheel well so as not to fail an MOT.
As a side note, if you plan on cutting the rot away and welding a new patch on, the weld must be a continuous one (ie no gaps) or it'll fail again. You do not, however, have to leave the repair exposed to the elements for the retest and are allowed to coat it with underseal. The tester does not have to see the bare metal repairs. I would also recommend drilling a drain hole to allow future water to escape as it's a perfect trap for leaky water "bottles".
-Simon
fightingtorque
« Reply #4 on: June 24, 2008, 12:50:29 PM »
Has to be a continuous weld but then you underseal it.   Won't be the first time I made use of that....
