Author Topic: Idling, Indicators & Garages  (Read 1594 times)
kerry
« on: June 18, 2008, 07:47:14 AM »
Hi there. I've got a few queries - had a search first and didn't turn anything up, so hope you don't mind a new post...
1. Picked up the car from the garage on Friday and he was idling beautifully. After a day or two's driving, though, I seem to need the choke out on a permanent basis. What's the best way to set it up to idle properly?
2. The indicator light on the dash doesn't work. I've checked the exterior bulbs and the fuse but they're OK. What's the most likely cause? Dud bulb? If so, how to get the instrument panel out?
3. Does anyone know of a reputable garage (who know 126's) in Bridgwater, Taunton or Weston?
Many thanks in advance.  :D
« Reply #1 on: June 18, 2008, 08:16:38 PM »
Sounds like a dud bulb on the indicators.
Idle problem could be anything but sounds like the mixture is going lean.
I guess if you took it back to the garage and gave them a chance to rectify the problem would be the cheapest way.
Either that or open the engine lid and turn the idle screw up a bit and see if that solves it. :roll:
