Author Topic: hot brakes  (Read 1543 times)
Setch126
hot brakes
« on: June 07, 2008, 07:25:22 AM »
Hello all,
a one off this I think but comment/advice welcome.
Rear nearside brake got V hot the other day for no good reason.
I hadn't left the handbrake on in error.
When I stripped the hub down to have a look I could find no obvious cause, all components moving freely etc. The only minor issue was that the handbrake was ever so slightly more 'keen' on this side, so I freed it off a little and hope all should now be well.
Am I missing anything else ?
Nick
1987 126 BIS Blue
hot brakes
« Reply #1 on: June 07, 2008, 08:10:29 AM »
Hi Nick, only thing that springs to mind is maybe a sticking wheel cylinder, as you have checked that everything is free just see how it goes.
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
hot brakes
« Reply #2 on: June 07, 2008, 10:15:05 AM »
Another possibility would be an out-of-round drum. These drums are very thin and if you are applying the handbrake strongly after a long run, the hot drum can be pushed into an oval shape by the shoes, and allowing it to cool down like this it can make the drum stay slightly warped, hence it will then scuff the shoes when moving and possibly heat up.
Just a thought.
hot brakes
« Reply #3 on: June 07, 2008, 10:22:22 AM »
Perhaps the handbrake cable was incorrectly adjusted? A lot of car owners adjust the cable to tight (to get a good handbrake), you should have some free play on the handbrake cable this so that the brake adjusters can work properly.
