Author Topic: Hazzard lights...  (Read 2496 times)
Hazzard lights...
« on: May 30, 2008, 12:33:26 AM »
Ive got a problem which is more electrical than mechanical. When i bought my bis my hazzard lights didnt work, after somme meddling with the relay i managed to fix them but now the lights go left-right-left- right.... this is getting quite embarrasing and i was wondering if there was a solution to this other than buying a new one...
ososilly
Hazzard lights...
« Reply #1 on: May 30, 2008, 06:39:41 PM »
I think them going left-right-left-right is perfect, quirky and unconventional...just like a 126!  :wink:
Hazzard lights...
« Reply #2 on: May 31, 2008, 06:55:54 AM »
Quote from: "ososilly"
Yeah, when i overtake a car, i put em on so i have the element of surprise, left or right??  :D
phreak97
  • Niki!
Hazzard lights...
« Reply #3 on: June 24, 2008, 02:50:48 PM »
usually that means it's wired up wrong.. i dont think the relay could break and cause this. check the wiring against the diagram that im sure someone here can post (i dont have it anymore).
have you got the right relay?
phreak97
Hazzard lights...
« Reply #4 on: June 24, 2008, 03:04:52 PM »
its the orig relay, the little black box under the wiper motor, and its wired up correcly, but the little thingys inside are not set up correctly, when i got the car only the left side worked, then my bro meddled with it and now both sides work, but not at the same time. (sometimes they allign and flash together, then they dont...) im just confused, and searching for a whole set of new relays (hazzard lights, indicators, intermittent wiper switch, and rad fan...)
at least i can say the horn relay is working OK...
phreak97
  • Niki!
Hazzard lights...
« Reply #5 on: July 04, 2008, 04:17:44 AM »
ummmm theyre meant to be running from just one relay when the hazards are on, which means it's impossible for them to flash at different rates.. theres no way your wiring is correct..
also, i dont know that much about a bis, but the relay you've got pictured there looks like the wiper relay in my aircooled, there should be two three pin relays other than that, one for indicators and one for hazards.
correct me if i'm wrong about that for a bis though, my wiper relay is also on the other side of the car to that, however moving it in the bis wouldnt suprise me because it was very much tacked on in the aircooled (regulated wipers were an afterthought)
phreak97
Hazzard lights...
« Reply #6 on: July 04, 2008, 11:01:55 AM »
i have it sorted out. my wiring os fine, but the relay i pictured (which is ther right one) was a bit messed up. ill try to explain it:
there are two little metal strips in it, and theyre supposed to go up-down together, and flash te lights, but they were not goin up and down together, so the lights went left-right, just took some experimenting and when i alligned the little metals together it works fine....
all those other relays (wiper, horn, indicator) are in that little black box next to this relay..
phreak97
  • Niki!
Hazzard lights...
« Reply #7 on: July 04, 2008, 12:56:33 PM »
that's still a very odd problem you had there..
sounds like the bis is different then, an aircooled doesnt even have a horn relay..
phreak97
Hazzard lights...
« Reply #8 on: July 04, 2008, 02:22:13 PM »
this is the relay box together with the fuses...
i know its a odd problem, newer saw a car do this...  :wink:
phreak97
  • Niki!
Hazzard lights...
« Reply #9 on: July 04, 2008, 05:16:10 PM »
that's very different to the aircooled. is there even a seperate relay for the hazards?
phreak97
Hazzard lights...
« Reply #10 on: July 04, 2008, 05:39:25 PM »
well as i said, the little black box under the wiper is the hazzard relay...
