Author Topic: MOT failure  (Read 2204 times)
MOT failure
« on: May 27, 2008, 05:09:14 PM »
I have just had the bad news I get ever year after my MOT. It's failed, I'm not sure what on yet, but will find out when I pick it up from the garage this evening. Apparently it was for 'a number of things' though - so not at all what I want to hear. One of the reasons will surely be that the wheels at the front stick out of arches a little.
Will ad the actual causes of failure later this evening. I think it always helps to know the reasons why each others cars have failed so we know what to expect/look out for when the time comes.
MOT failure
« Reply #1 on: May 27, 2008, 07:44:17 PM »
In actual fact - I'd guessed completely wrong, and it seems to be fine with the wheels slightly protruding the arches. (Not sure a policeman would see it like that, but then again they'd hardly notice).
It actually failed on things that I'd not anticipated at all.
1) The L/hand indicator was too dim and affecting the light above, causing it to dim slightly every time the indicator flashed (Bad earth - temporarily fixed)
2) This is the big one - They have said that there is excessive play in the steering.
- There is slight play, but there has always been in the 5 years I have owned and driven the car. I have tested my other 126 and it too has the same amount of play when turning the steering wheel gently side to side. So I'm not too sure how it is supposed to be or how to fix it. I have tried adjusting the steeringf box, but it has not yielded any results. Has anyone had similar problems, and how were they solved?
This is the worm and sector steering and not the later Rack and pinion.
MOT failure
« Reply #2 on: May 27, 2008, 10:30:17 PM »
dom its good news as yours is a left hooker , just replace the stering box and it will be okay it isnt that expensive, but if you have a uk car your in the poo as that rip off geezer ( abarth everything ) on e bay holds all the uk stocks of steering boxes and charges mega money for them
MOT failure
« Reply #3 on: May 28, 2008, 07:52:21 PM »
2nd time round and it has passed!
Amazing what people will do with a bit of 'Italian Family' persuasion!
 :lol:
I will keep a look out for a new steering box though as it did pass, but was issued with an advisory notice.
MOT failure
« Reply #4 on: May 28, 2008, 08:38:15 PM »
Thats good news Dom   :smt026
MOT failure
« Reply #5 on: May 29, 2008, 09:43:05 AM »
Back in business -  can finally fully enjoy those new wheels - now I need to work on tidying up the body work as my car is currently 3 colours, including a nice big coat of white primer on the right rear.
At least it drives, that surely, for me, is the most important thing.
