Author Topic: Reversing light switch  (Read 1702 times)
subvert73
« on: May 24, 2008, 09:06:23 AM »
Does anybody know whether it's possible to fit an automatic reversing light switch to a Polish 1978 126?
When I say an "automatic reversing light switch" I mean one that screws into the gearbox casing and switches the lamp on when reverse is selected.
Steve.
« Reply #1 on: May 24, 2008, 08:05:03 PM »
not sure, its a gearbox issue, but you can swap the box with a later model...  :)
(look at the box, and see if it has a hole in place where the switch should be...)
Bruce
« Reply #2 on: June 04, 2008, 01:03:32 PM »
i had a 1979 italian 126 with no reversing lights and i fitted the reversing light and lamps from a limited edition black car and it worked peachy.
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
« Reply #3 on: June 05, 2008, 12:03:50 AM »
You may want to consider the option of fitting a pin switch similar to the handbrake idiot light switch at the gear selector rather than at the gearbox itself. Not necessarily the best way but another option if you hadn't already gone down that route. I'm sure there would be a way to make it hidden from view.
