Author Topic: Sagging Doors  (Read 2786 times)
Normansinjunstevas
Sagging Doors
« on: May 21, 2008, 04:53:32 PM »
Dear Comarades,
Do any of you know a good method to raise a slightly drivers' door?
Mine is is definitely sagging by a few millimetres, andneeds a good "slam" to close it, which I'm sure can't be doing the striker plate & lock much good.
Any suggestions would be greatly appreciated.
Big Respect.....Norman
Sagging Doors
« Reply #1 on: May 21, 2008, 05:12:02 PM »
I also have this problem, but with my passangers door, so cmon guys, help us out!  :cool:
Sagging Doors
« Reply #2 on: May 21, 2008, 08:42:36 PM »
is there any play in the hinges?
Normansinjunstevas
Sagging Doors
« Reply #3 on: May 21, 2008, 10:32:22 PM »
There's no obvious play that I can detect.
Is it possible to perform the same trick as used on Morris Minors...in that you place a piece of wood in between the door and the A pillar and distort it back into shape?
I thought that I'd best run it pass my like minded Brethren before attempting such a stunt.
Do you reckon that undoing the bottom two hinge bolts, and placing a spacing washer between the hinge and the A pillar might do the biz?
With Respect.....Normski
Sagging Doors
« Reply #4 on: May 21, 2008, 11:05:30 PM »
No play in the hindges. Norms, you just might be on to something there, try it out, and let me know how it goes  :lol:  :cool:
Sagging Doors
« Reply #5 on: May 22, 2008, 04:06:54 PM »
when i used restore classic cars if we had a door that was out we would shim the door with a metal plate until it fitted other trick is to jack the car up pop a sturdy peice of wood under the open door (a littele ajar not fully open) and lower the jack carefully and let the weight of the car do the work...both are worth a try
Normansinjunstevas
Sagging Doors
« Reply #6 on: May 22, 2008, 04:38:02 PM »
Cheers Stuey.
I'll give them both a try, and see what occurs.
Do you have to open the door really wide,as in fully open, or just wide enough to prop it up with the piece of wood?
Regards....Norms
Normansinjunstevas
Sagging Doors
« Reply #7 on: May 22, 2008, 04:39:35 PM »
Sorry Stuey,
I hadn't read your answer properly.
Cancel my last.
Respect....Norms
Maddog
Sagging Doors
« Reply #8 on: May 22, 2008, 05:15:53 PM »
if theres no play in the hinges then just loosen off the mounting bolts at the A pillar and raise the door up until it aligns properly. forcing it up is  more likely to just bend the door on a flimsy 126
Sagging Doors
« Reply #9 on: May 22, 2008, 05:29:42 PM »
I think (rightly or wrongly) what the guys are saying is that the doors have dropped at the latch end only  (bottom corner) and moving the door up will only move the problem elswhere,
the jack and wood idea isnt an ideal way of doing and should be approached with caution (place the wood against the door inner not the outer skin, its just a way effectivly adjusting the 'a' pillar slightly without major metal work..
Im certainly not suggesting you should drop the jack from a great height it needs to be approached very carefully..
sorry if I wasnt being clear about this.  :wink:
Normansinjunstevas
Sagging Doors
« Reply #10 on: May 22, 2008, 08:41:42 PM »
Brothers.
I've just had a go at inserting two spacers on the bottom hinge. It seems to have raised the door slightly, in that it closes much easier. Maybe with a little adjustment at the striker plate, it will be perfect.
It looks to have done the trick, and does not distort or damage the door in any way.
Thankyou all for you input. It is very much appreciated.
T.T.F.N......Norman
Sagging Doors
« Reply #11 on: May 22, 2008, 11:45:27 PM »
there are shims put at the door catch for adjustment .
phreak97
  • Niki!
Sagging Doors
« Reply #12 on: May 23, 2008, 03:07:38 AM »
when i got my car neither of the doors were alligned, but mine were due to play in the hinges which i fixed quite easily. take the doors off, get a large hammer as a support (i used a mini sledge) and hold it against one end of the hinge pin, then hit he other end of the hinge pin with another hammer (regular, whatever) it will cause the pin to swell and take up the slack.. keep going till the hinge starts to move with a bit of resistance (wont be noticeable with the door on) then move on to the next one.  be sure to keep the pins oiled too.
the pin is supposed to be fixed to the outside bracket and the inside sleeve is meant to move around it.. one of my doors is the opposite to this because my car was uncared for for a long time and the hinge rusted solid.. works fine surprisingly.
my drivers door didnt's close correctly, leaving a gap at the top of the door, in the end i got frustrated when it started raining and leaked on me, so i opened the door, wound the window down, put my feet out against the bottom of the door, and pulled the top of the window frame towards me.. the whole door twists quite easily, im hoping i dont ever have anyone crash into me :shock: but it fixed my problem perfectly.
originally when my doors had dropped, i tried to bend them back up as suggested here, but with a 126 you can bend it up by hand.. i just grabbed hold of it and pulled it upwards..
another method i tried for adjusting the hinges was putting a socket from my socket set inside the hinge then carefully pushing the door closed on it, as my hinge had been bent a bit, this bent it back.
is there any real (cheap) way to replace the little metal loops which hold the door limiter? i've got a broken one on each side, and so does my friend.. the panel in front of the door has become my limiter, and theres a little dent with no paint on it there on each side :(
phreak97
