Author Topic: 126 bis valve clearances  (Read 3005 times)
Richrimmo
« on: May 11, 2008, 10:38:06 PM »
Anyone know the valve clearance settings for 126 bis 1992. what sort of job is it ?
« Reply #1 on: May 11, 2008, 10:54:16 PM »
http://club126uk.co.uk/index.php?ind=downloads&op=entry_view&iden=7
you need to remove the exhaust but other than that its a simple job  :D  :D  :D
« Last Edit: March 20, 2011, 07:07:53 PM by ChrisRLewis »
fightingtorque
« Reply #2 on: June 23, 2008, 01:14:04 PM »
I just did this job.  It is possible to do with exhaust in place, it's just a bit difficult to find the right orientation to get the tappet cover off and out between the exhaust pipes.
< Then the next time I tried it, I couldn't get it out! >
Note that in the fiat 126 owners handbook they have made a misprint on the clearance specs - I presume the metric numbers are correct but the imperial specs (my feelers are in thousands of an inch) are wrong as they do not correlate by a factor of 10.
Of course it also turned out that I was looking in a manual for an aircooled that came with my car, but it is a watercooled, and the specs are different, so I had to do it all over again afterwards!
