Author Topic: 2 x rubber seals - drive shaft - WANTED!!!  (Read 2095 times)
toby-toby-two
« on: May 08, 2008, 10:53:10 PM »
I hope hope someone is able to help!  My Fiat 126 has recently had a new clutch fitted, and the car was working fine.  However, the car started acting up and the garage have took another look and now say I need 2 x rubber seals that go into the drive shaft, which they are struggling to locate.  I wonder if anyone can help!  Kind Regards,  Sandra (a desperate fIAT 126 OWNER)!!!!!!!!!!
« Reply #1 on: May 08, 2008, 11:58:53 PM »
I guess these are the gaitors that you are after
http://cgi.ebay.co.uk/Fiat-500-126-Pair-Inner-Drive-Shaft-Boot-22mm_W0QQitemZ290196631835QQihZ019QQcategoryZ31352QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
alternatively they can be purchased from Axel Gerstl
http://www.fiat500126.com/
Check with the sellers first that they are suitable for the Bis model!
« Reply #2 on: May 09, 2008, 12:46:30 AM »
if you want them the next day try,
http://www.ricambio-web.fsnet.co.uk/
give them a ring i found them very helpfull the contact number is on the site  :D
if you order them from gersts they'll take a week to arrive if they have them in stock.
