Author Topic: Electrical problem? Won't start.  (Read 1474 times)
Italdesign
« on: May 04, 2008, 01:56:35 PM »
Hi, since I fitted a Panda 30 head with Dellorto DHLA carb to my 1985 FSM Niki I have only been able to start it once. (Before my modifications it started perfectly).
The carb may not be set up properly, but fuel is getting to the spark plug. There is a spark but it seems a bit weak. When I turn it over on the starter it spins over happily but makes no attempt to start.
It has the square twin spark coil and the wasted spark syatem. I had an auto electrician check the coil, and have replaced the points, condenser, leads, and plugs. - Made no difference! Have checked and rechecked the static timing.
There doesn't appear to be a ballast resistor, but the wire to the coil is a resistance wire?  I measured 15v where the orange +ve wire joins on to the light blue resistance wire, and 6v at the other end, ie. at the coil.
Does this seem right?  I tried taking off the +ve wire to the coil and running a spare wire to it from the battery but the car still won't start.
I'm really stuck and feeling stupid.
Stephen
« Reply #1 on: May 05, 2008, 12:34:43 AM »
Hi Stephen. welcome to the forum as you have replaced most of the ignition system and you have a spark at the plugs the only thing i can suggest is if you have someone in the car turning the engine while you turn the distributor and see if it fires up, if you have had the distributor out it could be that its 180deg out, mine has the waste spark ignition and i had a similar fault, took me two weeks to figure it out, when you look at the ignition circuit it looks like it should'nt make a difference but i found out it does. let us know how you get on.
