Author Topic: Front Lowering  (Read 2048 times)
jon.hunt
Front Lowering
« on: April 28, 2008, 05:28:18 PM »
Hi all,
          I've fitted my Reverse Eye Front Spring to my 126 and yes it is LOW,  But the Drive is Awful, It's like there's no travel at all, and if you hit a Bump the Car just sort of Jumps over it, or slide's sideways a little, Real Skitty and unnerving!!!!!!   Is there any way of Highering it a Little, short of replacing the Original Spring.  I must point out that I have 13" wheels with Low Profile tyres which again doesn't help the suspension, It's Just to Solid.
                                     Jon.
Front Lowering
« Reply #1 on: April 28, 2008, 06:45:05 PM »
Hi Jon, if you have just replaced the spring you need to get it tracked up, mine did the same (bumpsteer) to the point it was dangerous bouncing about the road on every small bump. was the best 30 quid i'd spent. also fit a pair of rear shockers to the front they are a shorter lengh and match the reverse eye spring although they are a little stiffer. you will be amazed what a difference this makes, mine drives true and straight without any vibration at motorway speeds.
P.S. take the manual with you with all the settings and clean the trackrod end threads soak them with penatrating oil before you go.  :)
Front Lowering
« Reply #2 on: April 28, 2008, 08:02:34 PM »
You high-end tuner guys are newer satisfied... too high, too low... blah blah blah.  :P  :D
ill be glad to get it back on the road, be it as high as a hummer  :cool:
Front Lowering
« Reply #3 on: April 29, 2008, 02:09:01 PM »
Hi John,
I have exactly the same problem as you. I have recently fitted a reverse eye spring with rear shocks to my 500. It sits at just the right height. I have found it bouncing over the road a little too. As a solution to this I lowered the tyre pressure quite a bit, It now drives fine in a straight line and on turns. However the steering is a little heavy and I'm not sure it's doing the steering components a great deal of good. I am still yet to get the tracking properly sorted and now the MOT has run out!
I have also noticed a high pitched squeaking sound on the right hand front wheel. I think it's telling me the kingpins are due a nice pump of grease
Front Lowering
« Reply #4 on: April 29, 2008, 10:28:51 PM »
have a check to see if your running on the bump stops and if so cut them down a little , my car is running with a reverse eye and rear macs up front its so stiff i cannot put the front down without risking denting the wing!!! but it drives spot on , dont forget that these cars are a little crude in the first place so dont expect it to handle like a modern setup. if you dont like the leaf spring get shot of it and chuck some wishbones and coilovers on it .
