Author Topic: Its a Spark thing --- SORTED  (Read 3683 times)
DazedandConfused
« on: April 26, 2008, 06:00:39 PM »
Hmm where to start.
Bought the 126 1981 Fiat two years ago and there it sat in the drive, because i build custom bikes too.
Anyway ........ its always started and then 2 months bfore the MOT i wouldn't so i changed the starter bushes and hey presto..... life.
After not being on the road for 8 years all it needed was four bulbs and wiper blades, and MOT was given. Not to say i did service the whole car in a week.
We took it out for a maiden voyage on the road and after 7 miles, it  went  blah blah then stopped.
Towed it back and we had no spark at all so i replaced plugs, condensor, coil, leads and distributor.
Still no sparks tested all with multi meter and no volts from the coil still.
So i'm thinking may be in the steering column housing and electrical pathways..... but open to suggestions or others had this problem. ??
 :shock:   cheers
DazedandConfused
« Reply #1 on: April 26, 2008, 06:50:53 PM »
it gets better now ....while out double checking things ...gapping plugs, i could swear here ......... the plug from cylinder 2 FELL ...FELL out of the socket wrench and down into the fan area !!!!!
Now is this a ..." you need to part dismantle the engine to retrieve it "  section !!!
« Reply #2 on: April 26, 2008, 06:55:54 PM »
Hi. Welcome to the forum,
If you have a lead with two crocodile clips you can connect this to the thick red wire on the starter motor (pos' live) as this is a constant supply and the other end to the pos' on the coil and see if it starts, if it does the problem must be either on the resistor wire to the fuse box or the lead to the ignition switch, or even the ignition switch. let us know how you get on.
DazedandConfused
« Reply #3 on: April 26, 2008, 06:58:40 PM »
cheers Pete ........ any clue on the lost plug bit !! ??
« Reply #4 on: April 26, 2008, 07:18:28 PM »
Hi Mate, Don't really know which would be the best way as mine is a bis watercooled, i can only see two options in the aircooled manual and that is either remove the dynamo with the cooling fan or it maybe possible to remove the bottom section of the engine undertray, someone on the forum might be able to advise.
« Reply #5 on: April 27, 2008, 11:52:40 AM »
I would try one of the magnetic tools for picking up ferrous bits. Get one with a bendy shaft, it might save you a major strip down job.
DazedandConfused
« Reply #6 on: April 27, 2008, 12:20:47 PM »
thanks but i just finished rebuilding cooling top end ..... bit of a crap job in a tight space but down it...... it was resting on the edge.
Waiting for battery to recharge itself before i give it another try to start...........
But just one question ..... when the ignition key is turn to the on position should there be a 12 volt reading from the positive on the coil or not until the engine is turning over ?
DazedandConfused
« Reply #7 on: April 27, 2008, 01:26:50 PM »
Update !!!!!!!!!!!!!!!!!!!!!!!!!
ignition key / switch ok and power going to coil......  double checked the timing and when i connected the bulb gizmo to the earth then distributor the bulb didn't illuminate (not blown), assuming i'm correct that this means the condensor is faulty and yet again i need to replace it !!! and / or there is another unit attached to the coil which is a suppressor could this cause a fault too.
your thoughts please !!!  :twisted:
« Reply #8 on: April 27, 2008, 03:13:56 PM »
I am not sure on this one? but I dont think that a 1981 aircooled used the ballast system, so you should get approx 12-13v at the coil.
Do you get a spark at the points, checking with the ignition on and the dizzy cap off using a screwdriver to flick the points open?
DazedandConfused
« Reply #9 on: April 27, 2008, 06:31:52 PM »
yes there is a spark and its blue..... do you think i should re gap them !! and 12 volts is reading fine !!
« Reply #10 on: April 27, 2008, 06:53:23 PM »
Well thats good news Steve, when you tested it earlier with your circuit tester did you check that the points were open, cause if they were closed this grounds the distributor and the bulb would'nt light up. if it all checks out now i'd check the fuel system and then do a compression test to make sure the head gasket has'nt gone,
« Reply #11 on: April 27, 2008, 09:34:54 PM »
have you tried taking a spark plug out with it still connected to the HT Lead and earth the spark plug thread, spin it over with the ignition on, is there a spark at the plug?
If the plugs seems to be getting wet it usually suggests an ignition problem on the other hand if they are dry it's a fuel problem.
Did you also put fresh fuel into the tank? petrol does go off especially after 2 years!
DazedandConfused
« Reply #12 on: April 28, 2008, 06:33:19 AM »
Quote from: "ChrisRLewis"
have you tried taking a spark plug out with it still connected to the HT Lead and the spark plug thread to earth. spin it over with the ignition on, is there a spark at the plug?
If the plugs seem are getting wet it usually suggests an ignition problem on the other hand if they are dry it's a fuel problem.
Yep done all that, learnt that from building harleys for 12 years. Electrics aren't my strong point through patients but had a flash thought while sleeping.
In the distributor cap when the rotor rotates past the HT points inside how much of a gap should there be ? Even though its a new one it seem to be quiet a lot ?
DazedandConfused
« Reply #13 on: April 28, 2008, 10:44:22 AM »
Right i found another fault but this could tie in and cause the start problem ??????
The horn will not engage when the wipers are on and i noticed that the orange wire is connected to the wipers !!!
just a thought
DazedandConfused
« Reply #14 on: April 30, 2008, 02:49:59 PM »
Turns out while the car was serviced the contact in the centre of the distributor had fractured and fallen into the points, luckily it didn't damage any other ignition parts.......... so the car got a complete ignition system and i now have a spare !!
What Joy and thanks for yer help guys  :twisted:  :twisted:  :twisted:
