Author Topic: Camshaft  (Read 1695 times)
jon.hunt
Camshaft
« on: April 20, 2008, 09:25:58 AM »
     I have a 126 with a Skimmed Panda 30 Head Breathing through a Dellorto 40 DHLA into a Performance Exhaust. The car has a Standard 1987 Cam, in it, It Runs Real Great, but would like still More Power, and I wonder if a Proietti 40/80 Cam. is the next thing to do, or is it only a Marginal Improvement, if so I shall leave well alone as it goes real Smooth now.  Also is it possable to change the Cam. with the Engine in the Car? I guess take off the rear Bar/ Sump/Timing cover and the timing gear on top of the Head, is this the Way or should I leave alone?
                              Jon.
Camshaft
« Reply #1 on: April 21, 2008, 11:33:40 AM »
you can change the cam in car but its so much easier to work on out of the car in the long run.
