Author Topic: Problems after gearbox rebuild - 126BIS  (Read 3315 times)
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
« on: April 09, 2008, 07:30:18 PM »
Hello Everyone
I have recently bought my wife a 1989 126BIS for not much money, due to a gearbox problem. She was jumping out of third gear and would occasionally get stuck in second. I was assured the entire linkage had been replaced already, meaning a new/rebuilt gearbox was required.
I have just finished rebuilding the gearbox using the Ricambio repair kit, and now I am having trouble engaging first gear. When first starting up, you can engage first but it doesn't have the "feel" of the rest of the gears, ie it's not a positive selection, it doesn't feel properly engaged. After reversing out of the garage and trying the other gears, first is no longer available at all. Incidentally, reverse gear is fine.
I drove around the block and third still pops out. Strange thing is, when I pulled in to the garage and stopped the engine, I played with the selector for a while and then when I started up, first was semi-available again - the same as above.
I have read about an adjustment at the gearstick, but I only have a Haynes manual for an aircooled model and my gearstick looks different. I couldn't see any adjusments but I may have missed them - are they only on the aircooled models? What else could be causing this? I am confident that the rebuild was successful and I have heard no strange noises to suggest anything has broken or sheared...but obviously something is wrong.
Any advice would be gratefully received!
Regards,
Simon
« Reply #1 on: April 09, 2008, 08:46:50 PM »
Welcome to the forum Simon, if everything has gone back according to the manual, the only thing i can suggest is check the two gearbox mountings if they are shot maybe they could be pulling it out of gear due to excessive movement, also check the flexible coupling on the gear linkage.
there is a couple of forum members that have used the repair kit if you wait a couple of days i'm sure they may be able to help.
rockchevy85
« Reply #2 on: April 11, 2008, 07:06:00 AM »
Thanks for the reply, Pete, and the welcome.
Both the gearbox mountings and the flexible gear linkage appeared to be new / nearly new when removed from the car, but next time I'm there I will have a look to see if there is any movement front to back.
I have now spotted what could be an adjustment bolt on the driver's side of the transmission tunnel, and when I slackened this bolt I was able to hit first, but now I can't touch any gear at all. Could someone confirm this is an adjustment bolt, and how to properly utilise it?
Thanks and regards,
Simon
Pawel83
« Reply #3 on: April 11, 2008, 02:16:48 PM »
These two things are adjustments bolts. They're on the passenger's side. (in air-cooled model, but probably in bis it's the same). You can move the lever forward or backward if you unscrew them
lilgreencar
« Reply #4 on: April 11, 2008, 07:43:03 PM »
Here's how to adjust the gear linkage using 2 adjustment screws pointed out in the above diagram:
1. Put the car in reverse
2. Get underneath the car and undo the linkage flex joint connection completely
3. Push the rod as far as it will go into the gearbox by hand
4. Loosen the adjustment screws on the side of the tunnel and move the linkage back and forth until you are able to bolt up the flex joint under the car to the rod, without having to move the rod
These instructions are courtesy of Paul from the 500 forum and worked perfectly for me:
http://500chat.fiat500club.org.uk/viewtopic.php?t=5891
cheers!
lilgreencar
rockchevy85
« Reply #5 on: April 12, 2008, 10:17:30 PM »
Thank You everyone for your responses so far. I have adjusted the gear selector as described above but it has made no difference. I have, however, found something which could explain it.
Having carried out all possible adjustments and checked the gearbox mounts, I discovered that if I sat stationary with the brake on, selected third and engaged the clutch it would grind the gear even if I held the gear stick in place. My dad watched for engine/box movement at the same time but there was none. This tells me the problem lies within the gearbox.
I removed the engine and box again and stripped the box down (getting quite quick at it now!) and discovered there is a fair bit of play in the output shaft, front to back. When I engaged third gear by hand and moved the shaft, the two meshed gears move far enough apart to slip. I think the shaft must be pulled out of alignment by the sheer turning forces.
So after stripping the output shaft I discovered the front bearing has all but disintegrated. I think this is what is allowing the excess play in the shaft, and so I will be needing a new one. Can anyone recommend where I can get one of these? The bearing is inscribed with Pollard CBK-168 FLT4
Thanks in advance
Simon
« Reply #6 on: April 12, 2008, 10:57:11 PM »
Perhaps a bearing supplier can help you. I have a good one locally just requires the old bearing for a match.
rockchevy85
« Reply #7 on: April 26, 2008, 06:51:38 PM »
Well, I managed to locate a bearing from Axel Gerstl - cost about £20.00 with delivery - and it has fixed the problem. After a marathon rebuild and installation this morning and afternoon I have successfully driven around the block using all gears with no issues at all. It would seem that the collapsed bearing was allowing the entire output shaft to slide out of mesh when in third, and this allowed the gear to jump out of mesh.
Thank You to everyone who posted advice and sent diagrams relating to this issue. I'm sure I'll be able to return some advice once I have had to maintain this car for a little while!
Regards,
Simon
rockchevy85
« Reply #8 on: May 19, 2008, 11:22:04 PM »
It seems the problems are not all together solved, as I found out on our holiday in France last week.
We were performing some kind of manoevre through a little French road when suddenly I had no gears. The gearstick felt as though it was in the neutral position, but there was less play in the stick and the car would still drive. I pulled over and played with the adjustments as detailed above but to no avail. I eventually (after getting back to our accomodation in second gear) took the front of the gearbox off and found that even though the shaft at the front of the gearbox was pulled forward to the neutral position, the lower engagement fork was pushed forward and the car was in second gear. It was as if the selector fork had jumped to the other side of the three engaging fork arms. After pulling the lower fork back to neutral and reassembling, the car was fine again for about 300 miles (enough to get home), and then the same thing happened again today. I took some pictures this time, and as you can see the selector rod is in the neutral position in the first picture but even here the car is in gear.
I can't see any signs of wear that would suggest this jumping, there is a little wear on the rod in the second picture but surely that's not enough...but I can't think what else could be happening. Any ideas?
How I found it :
Can't see any wear here?
