Author Topic: Dwell Meter for 2 Cyls?  (Read 1663 times)
« on: April 08, 2008, 05:05:33 PM »
I have just had a request for information for a suitable dwell meter for a 2 cylinder engine. Apparently it seems that only 2,4 and 6 cyl meters are available?
Anyone able to help with this query?
Wozza
Dwell meter
« Reply #1 on: June 04, 2008, 04:22:19 PM »
Hi Chris, I haven't seen a suitable dwell meter for a 126 so far. But, if you still need one, try looking for a Gunson Digital engine Analyser, part number: 4142. It's a very useful electrical test meter, which has a duty cycle setting: Ie It can tell you what percentage of 1 second that any particular wire becomes a live connection. You can use this at a set Rpm,(Using the choke, and a tachometer.) to calculate the dwell angle, or determine the efficiency of your contact points setting. Hope that helps.
 Warren.
