Author Topic: Disc brake conversion  (Read 2408 times)
« on: April 02, 2008, 09:23:34 PM »
Im gonna be doing a front disc conversion on the BIS soon, need a little help with regards to parts for it- I have the conversion mounting plates and spacers from trs, and a set of caliper carriers and calipers en route apart from discs and pads is there anything else I well need to complete the conversion?
(I intend on using this thread as a photo graphic build up for future reference)
« Reply #1 on: April 03, 2008, 12:13:01 AM »
Stuey good luck with the project!
Don't forget to take loads of photos. I can then add this project to the Owners Guides section... :)
Regards Chris Lewis
« Reply #2 on: April 03, 2008, 09:45:46 AM »
Depending on what callipers you use, you may need a new set of rubber flexi hoses. As when I changed mine, the thread on the original hose was too fine for the calliper - though rather than getting new hoses, I got the calliper re-tapped.
I used old Fiat 1 pots from a 124 I think.
« Reply #3 on: April 03, 2008, 06:59:47 PM »
I did buy a set of 126 goodridge hoses... I'll have to check that..
