Author Topic: Brake Shoes Lining thickness !!! ???  (Read 1685 times)
gserghiou
« on: April 02, 2008, 09:34:01 AM »
Hi All,
I replaced my master and all 4 slave cylinders and tried to bleed the system...tried and tried...and foudn out that one of the slave cylinders (front left) is leaking oil...
i inspected it and it seems that the slave cylinder pistons  are pushed far out, so far that they push the rubber seal out of its seat, causing it to leak !!!
So...i figure :
1. i was given the incorrect slave sylinders (highly unlikekly)
2. My shoes lining is wearing thin...
3. my drums have been lathed to be smoothed inside and they the internal diameter has increased,
My questions:
1. how thick should the brake show lining be when new ???
2. what is the internal diameter of the front drums ??? this is a 1977 Italian Personal 4 car (i dont know if its any different  than later Polish models) !!!
3. Are the slave cylinders for the italian P4 different that the later polish ones ???
Please give me your thoughts !!!
Thanks,
George
(Cyprus)
Maddog
« Reply #1 on: April 02, 2008, 04:18:28 PM »
Hi George,
this is a difficult one to help with without actually seeing the brake/car in person.
firstly, are you sure the piston is being pushed to far out and it is not just a defective wheel cylinder?
 although there are two styles of brake drum identified by having either early 500 style or later style wheels, I think both early and late models use the same size drums/shoe/wheel cylinder
there should be around 7-8mm of lining material on new shoes
you can measure the internal diameter of your drums and check against the size given in haynes comic
did you physically compare the old wheel cylinders against the new ones?
are the adjusters in the centre of the shoes fitted correctly over the pin in backplate?
gserghiou
« Reply #2 on: April 02, 2008, 09:49:45 PM »
hi maddog...
a visual inspectin of th old and new cylinder looks like they are the same !!!
my brake lining is indeed not 7-8mm...only about 3-4 mm....
the piston seems to be pushing too far out, pushing the rubber itself out of its seat ....
i will check the adjusters as well...
but the brake lining on all shoes is going for a overhaul....get some new ones glued at the specialist....
Will let you know of the outcome...
Thanks,
George
(Cyprus)
« Reply #3 on: April 03, 2008, 09:35:59 AM »
strange problem this one??
just an idea, have you checked that you have put the correct side slave cylinder on to the brake backplate? they may be handed?
