Author Topic: KINGPIN REMOVAL ? WHO SAID IT WAS EASY !  (Read 1716 times)
BLUDGER
« on: March 31, 2008, 08:10:20 PM »
I consider myself to be a competent home mechanic, having rebuilt several motorbikes. HOW ON EARTH DO YOU REMOVE THE RUBBER BUSH IN THE STUB AXLE CARRIER WITHOUT FINDING SOMEONE WITH A 10 TONNE PRESS??. I have tried using a vice and old sockets but without any success. Any sugestions anyone ?
« Reply #1 on: March 31, 2008, 09:18:49 PM »
Hi Mate, your not the only one who's had problems refurbing kingpins, unless you have the specialized equipment i.e. reamer and press you will struggle,
 http://club126uk.co.uk/forum/viewtopic.php?t=2338&highlight=kingpin+removal
« Reply #2 on: April 01, 2008, 07:29:30 PM »
i got a press and even i strugled! if you can get the rubber part out ( ie burn it or cut it ) you can cut the outer part of the bush with a hacksaw and beat down on the top of the hub - through the hole at the top - and colapse it then tap it out but your right they are a ba***rd.........wait untill you try the pin itself!!!!! :shock:
BLUDGER
« Reply #3 on: April 01, 2008, 11:41:23 PM »
Thanks, I've already got  a reamer that I've used to ream out small ends ec on the bikes I've restoed and will persivere with getting the bush out.
