Author Topic: Oil Change  (Read 2136 times)
Scouse_126
Oil Change
« on: March 23, 2008, 10:17:46 AM »
Hi all,
Ive recently joined up on this site after getting it from the previous owner of my 126 BIS.
Im in need of a little help regarding an oil change. What do i need exactly, what type of oil would you recommend, how to go about doing it.
I have obtained a 126 manual but it only covers models from 73-77 and mine is a 91.
Ive seen a couple of posts regarding cleaning something up when doing an oil change, to remove sludge and gunk.
I feel a bit of a tool regarding this as i went into my local halfords asking about parts eg oil filter, and they just laughed!
Hopefully you will be able to advise me on this and give some greatly appreciated advice.
Cheers Scouse
Oil Change
« Reply #1 on: March 23, 2008, 09:59:13 PM »
Welcome to the forum, hope this helps.
Drain the oil
take off alternator belt
jack the engine up so the jack just takes the weight of the engine
undo the clips on the back panel and pull out the distributor wire and vacuum hose
undo the the engine mounting bolt (at the top of the rear panel and remove)
lower engine two to three inch and remove the rear engine mounting spring
disconnect the three wire connectors (for rear lights)
remove the four 10mm bolts on top of the rear panel
remove the four nuts on the inside of the rear panel (two at each end)
slide the whole of the back panel off
remove the six 10mm bolts on the filter
remove the filter cover
remove the oil thrower
remove the 32mm nut and deflector
remove the front pulley
clean all parts and re-assemble
re-torque hollow nut 32mm to 14.7 daNM
use any good quality 15w-40w oil
Scouse_126
Oil Change
« Reply #2 on: March 24, 2008, 12:37:14 PM »
Cheers Pete, I'll give it a go.
Thanks for all your help.
Oil Change
« Reply #3 on: March 25, 2008, 08:43:46 PM »
Thats the spirit, if you get stuck give us a shout :) its often overlooked at every service and can cause big end and main bearing problems, this is what i found when i bought my 126.
Oil Change
« Reply #4 on: March 26, 2008, 12:56:22 PM »
same thing on mine, never cleaned...  :shock:  :???:
Normansinjunstevas
Oil Change
« Reply #5 on: March 29, 2008, 05:51:19 PM »
So does that mean that any faeces just gets spun out into that collecting space then?
