Author Topic: rear wheel bearings  (Read 1914 times)
rear wheel bearings
« on: March 22, 2008, 07:08:11 PM »
has anyone done a rear wheelbearing before on a 126 or 500 ( i think there the same ) because the manual says that the rear hub nut needs to be tightened with a special weight? is there a torque figure i can use?
cmaranto
rear wheel bearings
« Reply #1 on: March 23, 2008, 10:54:09 AM »
Well......here is what I do, and who knows if its OK, because nobody does it the way the manual says.
On a rebuild, particularily if you have replaced the spacer, which is designed to be crushed, what I do is tighen the new bearings to about 35 to 40 lbs torque to make sure that the bearings are seated down properly and the spacer is crushed, then back off the nut till I feel the wheel has some side to side play, then I tighten it up till there is no play.  I have found that it is best to remount the tire so that you can grab the tire and wiggle it a bit.  Once I have removed all the free play, I tighten the nut another 1/8 turn and stake the nut.  After a few trips here and there, I will jack up the rear and wiggle the tires to see if there is any freeplay just to check. If there is, I tighten the nut till the play is gone.  It takes maybe 5 minutes to do this adjustment.  Usually never worry about it again. I've done this for 500's, 600's and 850's for 30 years, and never had a problem.  The rear bearings are bit of a dumb-ass design, but once its done, they will last for years.  So maybe that makes them a brilliant design.  Go figure!  The fronts are so much easier to do, but will loosen up with age.  Once the rears are set, they pretty much stay put.  Naturally high quality bearings and a high quality synthetic grease is a necessity!
hudsonhenry
    • http://www.retro500.com
rear wheel bearings
« Reply #2 on: March 23, 2008, 11:55:00 AM »
As cmaranto says...
 i also do mine by feel, do it a little bit at a time, you need to just get rid of the play but no further, make sure that you stake the nut into the hub and re check after a few miles (vital) as they can loosen off when they settle.
