Author Topic: Devastating MOT report  (Read 3070 times)
AngelaS
« on: March 19, 2008, 02:51:54 PM »
:sad: My little car has just failed its MOT and the garage reckons £700 to repair!  What I want to know is if people think this is fair for work?  Failed on (allegedly): offside lamp function impaired; exhaust system major leak (but they can't see where from);nearside and offside front brake pipes excessively corroded, offside rear t piece to brake pipe excessively corroded; brake hose ferrules excessively corroded; track rod end ball joint has excessive play, king pins siezed, front brakes imbalanced.
The mechanic sounded nervous, I 'm not sure if he thought I'd believe anything  - as we all know, it might be as cheap to get a whole new car!!!
AngelaS
« Reply #1 on: March 19, 2008, 03:52:10 PM »
id have a look at all the area's listed, and replace any parts on the cheep... like getting parts from members or ebay, then take it back to a different MOT centre... 700 is very excesive in my honest opinion...
« Reply #2 on: March 19, 2008, 04:28:36 PM »
Considering there is no body work or welding to be done, £700 is extortion! It sounds like it is a matter of replacing or reparing a few ralatively simple off the shelf parts. Did they say that that quote was inclusive of parts?
Definitely take it somehwere else.
Maddog
« Reply #3 on: March 19, 2008, 04:58:20 PM »
Hi Angela, £700 sounds excessive, here is a quick breakdown which may help you.
the reflector on the lamp is probably shot, is the silver very dull/corroded? hard to find replacements, try a wanted ad pn this site or the guy in ebay shops, make sure you don't get a LHD one by mistake
exhaust is one piece, £35, but manifold studs can be rusty making it dificult to remove, else it might just be the gaskets but just as tricky to remove. could take 30 mins or 3hrs depending on how rusty the studs are
£25 for the pipes plus 2-3hrs labour
 track rod end ball joint has excessive play, £8 plus 1hour labour
 king pins siezed,
grease them, 15mins labour
 front brakes imbalanced,
 may just need the adjusters freed,  2 hours labour to strip check and replace any parts shoes(£15)/wheel cyls(£10) or possibly drums at £20 each
a good little garage would do the lot for £2-300 inc parts.
get the headlamp and exhaust yourself as most garages will struggle to get these parts
AngelaS
« Reply #4 on: March 19, 2008, 05:45:25 PM »
Hi Dom, Yes the quote was for parts and vat an labour.
AngelaS
« Reply #5 on: March 19, 2008, 10:04:30 PM »
You guys really have it tought... here, as long as you have wheels, and at least two working brakes you pass the test, no porb...  :D
« Reply #6 on: March 20, 2008, 12:42:28 AM »
and we have con men, under disguise
« Reply #7 on: March 20, 2008, 10:50:25 AM »
:smt044
« Reply #8 on: March 20, 2008, 01:14:00 PM »
to be honest what type of garage did you go to? if you took it to a modern dealership who charge the earth and are very reluctant to work on cars where you do not plug a lap top in then its a normal sort of quote . if you took it to a normal working garage then they are indeed trying it on. this is fortunate for you though as its your chance to become intimate with your car and nurse it back to a healthy state with the peace of mind that your saving a shed load of money . :lol: a little tip for bis owners who are prone to breaking exhausts through stress fractures and throwing brackets bolts etc. take your car to quickfit ( believe me its not lunacy , you will understand ) and get them to fit a new exhaust , you will pay over the odds for it however its then guarranteed for a year so any problems with it during that time and you get a new one ! plus each time they fit the new one its guarrantee becomes re validated for a year so it never runs out! just as long as you can manage to break it before the years up... i did this  with my 1st bis and it was the best overcharge i had ever had!! any how dont worry about the car failing get your hands dirty and any problems just chat to your friends on the forum . :D
« Reply #9 on: March 20, 2008, 06:36:15 PM »
Won't work on my Bis, exhaust has been on there for 2.5 years now with no probs.
« Reply #10 on: March 20, 2008, 11:05:43 PM »
i belive my exaust is still orig, polish??  :shock:
