Author Topic: 126 Brake dilemma  (Read 2971 times)
cmaranto
126 Brake dilemma
« on: March 18, 2008, 12:19:45 AM »
New to the forum so here goes.  Live in Indy so nearest 126 is probably in Canada somewhere, therefore need some help.  Replaced the Master, all wheel cylinders and hoses.  Bled the system the traditional 2 man way, then purchased a pressure system because I have several X1/9s (impossible to bleed).  Still no brakes.  When the pedal goes to the floor, the brakes just are catching.  It acts like the Master does not have sufficient volume.  I have to assume at this point that all air is out of the system.  Master piston is returning all the way to the end.  Res lines are clear.  Shoes are in good shape and adjusters are not frozen.  My Bianchina, with the same system, but with a smaller single circuit system, has dynamite brakes.  Have the correct 15/16th cylinders up front and the 5/8 cylinders in the rear.  Was thinking of putting the 3/4 on up front to reduce the required fluid.  Anyone have a suggestion?  I'm ready to give up and start restoring my 850 spider.  Help please
126 Brake dilemma
« Reply #1 on: March 18, 2008, 12:45:20 AM »
Welcome to the forum!
The 126 brakes can be a pain to bleed at times there are a few threads covering this problem.
Perhaps you could try Paul Harbinson's tip
http://club126uk.co.uk/forum/viewtopic.php?t=1173&postdays=0&postorder=asc&highlight=bleeding&start=15
126 Brake dilemma
« Reply #2 on: March 20, 2008, 12:32:44 AM »
Hi.
You said the master is new. Is it definately the correct type?
The reason I ask is that i fitted a 126 master cylinder to my 500 it took me 2 weeks to get the brakes bled. All the components were new, no air in the system, even using a pressure kit. just as if there wasn't enough fluid to push the pads out. My problem was that the 500 pedal box wasnt providing enough leverage to drive the 126 master cylinder.
if the piston pin is too short you wont provide enough push, if it is too long it will block the inlets from the reservoir.
(This isn't a very common problem. in fact I think i'm the only one daft enough to have done it so far!)
If thats not your issue then i'm not sure what is. You could trybleeding with the drums off. Tie the shoes together (further apart than normally held in the drums) this should draw more fluid into the cylinders then you'll have to force the drums back on.
Also, to encourage the 'not so' self adjusters, drive the car quickly in reverse then slam on the brakes. Repeat until you feel some improvement.
Michael
cmaranto
126 Brakes
« Reply #3 on: March 20, 2008, 02:50:26 AM »
Thank you both for your helpful hints.......and, alas, the problem has been solved.  I called the company that manufactures the pressure bleeder, complaining that the procedure provided was not sufficient.  The company "tech" guy gets on the phone and asked a few questions about my procedures, then added the following:    they recommend lightly tapping the master as the fluid is being forced through the system after pumping the master.  Sure enough, as I tapped the Master, copious bubbles appeared in the clear hose.  After many "tappings" and many bubbles, needless to say, I had solid brakes.  As the Tech guy explained:  Depending on the design of the master, small areas can collect air and are difficult to purge.  Tapping the master releases these bubbles.  Took the 126 outside (still 0 C here), backed her up and jammed the brakes several times.  Now have a hard pedal with about 1 inch of travel.  Not going to get better than that!  Hope this bit of info might help someone else.  By the way, if you really want to get frustrated, try bleeding an X1/9!  Better yet, try replacing the Master on an X1/9.  The world's most stupid design in an otherwise perfect car.
126 Brake dilemma
« Reply #4 on: March 20, 2008, 09:11:49 PM »
glad you got it sorted, that'll be a good one to remember!
I may have avoided that issue by sheer accident as i had to install my master cylinder upside down due to insufficient pipe clearence.
cmaranto
Upside down master
« Reply #5 on: March 21, 2008, 03:23:51 AM »
You had to install master upside down!  That has to be an interesting story.
Were you in some horrendous front end collision?
Chuck in Indianapolis
