Author Topic: Strange short  (Read 1849 times)
Strange short
« on: March 17, 2008, 10:06:30 AM »
Right, so I've finally swappaed gearbox, diff etc, put the engine back in. Expected to turn the key and right away rejoin the world of 652cc aircooled fun, but unfortunately thuis wasn't to be.
When I turned the key there was no power at all. During the 3 weeks the car has been off the road with the engine out I'd disconnected the + wire from the battery. I think maybe I should've disconected both? But either way, 3 weeks of no use combined with crap weather would probably drain a battery to some extent, but not completely. I then charged the battery and tried again. When the battery was disconected it was showing a reading of 10volts. Not full but enough to at least let the lights work - but they wouldn't. Whenn fully connected up, the battery reading from both termials read a complete 0! When the live or earth lead are disconnected the volt reading comes back. This must indicate some sort of short somewhere.
Wanting to hear the engine sound after so long, I decided to jump start the car. It then started, but was making an awfull crackling noise, like somehwere was sparking, this noise became worse if the clutch was pressed.
I have no idea why this is happening and why it is resulting in a 0 charge from the battery. Could the clutch cable be being used as earth for some strange reason?
Strange short
« Reply #1 on: March 17, 2008, 11:11:43 AM »
have you forgot to reconnect the earthing straps? check your connections to all electrical components on your engine as it sounds like you have a pos and neg connection somewhere thats making it arc. oh don ive gone and agreed to buy nigels mates engine and bits so watch out for a beast to appear in the near future!
Strange short
« Reply #2 on: March 17, 2008, 01:39:33 PM »
Wiked that will be dangerous!
I'll try and have a look what could be conneacted wrong. earth strap is connected as are all over things. Not sure if the jacking process has unhinged or tangled some wires? What are the likely suspects? The fact that the clutch seems to affect it is a little concerning to me though
phreak97
  • Niki!
Strange short
« Reply #3 on: March 23, 2008, 02:54:26 PM »
the best way is to look around where the crackling sound is coming from:P therell be some blackened wire/metal if it was arcing enough to be heard over the engine.
the only wiring i can think of which is near the clutch cable is the reverse light wiring.. check on that, but i doubt its the problem, since i think that wir just connects to negative through the switch anyway. also, much more likely, check the thick wire that goes to the starter motor, you would have had the starter motor out, and that wire has no fuse on it, so itll keep arcing forever instead of just blowing a fuse, itll also try to pull the battery hard to 0 if its touching any random metal. check thoroughly that you have it connected securely to the correct place on the starter motor, that no nearby metal is interfearing when the engine starts to move around, and that you havnt put any nicks in the wire anywhere.
also, if your battery is at 10v unloaded your car probably wont start, and your lights will likely barely show. the reason being (trying to explain simply) that its not just voltage you need, theres current you need too, (you cant really measure that easily though) and if theres not enough current available, the voltage will be pulled down (it tries to level itself out sacrificing voltage for current). try fully charging the battery, if it wont get up to 12v (or a little over) then its probably dead.
disconnecting only one of the battery terminals is fine, it wont cause any problems.
let me know how you go:)
good luck
phreak97
Strange short
« Reply #4 on: March 23, 2008, 07:54:47 PM »
Hey,
I managed to solve the problem. Cleaned all the terminals, earths etc. Tested for voltage current etc and tried it using an external power supply/regulator to see if the voltage/current was being lost anywere and all was ok. Charged the battery and it worked all ok. I think that the live mains wire from the starter was touchng the starter oull cable as it was very slack. Still not sure why pressing the clutch affected it though.
So far so good, now back to working on sorting my front end set up, as it is still riding remarkably high
