Author Topic: 126 bis brakes  (Read 1725 times)
welly272
126 bis brakes
« on: March 12, 2008, 07:34:31 PM »
Im have real bad problems with my brakes. Ive changed all the wheel cylinders, flexy hoses,steel pipes, shoes bleed them and have removed all the air but cannot get a good pedal. The brakes work but the pedal is crap, the pedal stops 1inch from the floor . Ive clamped the hoses off then i get a good pedal so it would indecate that the master cyilnder is ok. The only thing i can see is that the sel f adjustson the linings dont work has any one esle had this problem and if so whats the cure
126 bis brakes
« Reply #1 on: March 12, 2008, 07:43:59 PM »
I had a similar prob with mine, dk if its the same thing but here goes:
when i changed them for the first time i went to the store and got the same ones as the originals and put them on, they fitted perfectly, but braked like crap, then i found out that the self adjusting thingy was a tat longer than the orig, went back to the store and the salesman gave me an older model which works perfectly.
if u changed them recently, compare the S.A. springs if they are the same..
hope this helps
G
