Author Topic: towing  (Read 1904 times)
welly272
towing
« on: March 11, 2008, 01:58:58 PM »
do you have to disconect the drive shafts to be able to tow it on an A Fram???
towing
« Reply #1 on: March 11, 2008, 04:26:24 PM »
nope? just leave it in neutral, and take off the hand brake... we did it when mine was delivered.. and you see these cars all the time with built on A-frames for towing behind a camper
so to answer your question... NO
Paul
Setch126
Re: towing
« Reply #2 on: March 11, 2008, 07:48:02 PM »
Quote from: "welly272"
I have just sorted mine for towing behind my motorhome on an A frame. Trial runs behind my car were excellent, very stable.
Do not forget to turn the ignition keys to disconnect the steering lock !
My 126 BIS doesn't have a middle position between off and ignition on. It is not good practice to leave the ignition on so, I have fitted a quick release battery clip to the earth pole on the battery. This way I can disconnect the steering lock without leaving the ignition on when towing.
Hope this helps.
Nick
1987 126 BIS Blue
