Author Topic: Rear Camber - Wheels sloping, what can I do?  (Read 2744 times)
finlay
« on: March 08, 2008, 06:12:03 PM »
Its the one aspect of the 126 I dont like is the sloping rear wheels, alway slooks like the camber is completely wrong. Wondered why the cars do that and what if anything can be done to minise it?
« Reply #1 on: March 08, 2008, 07:57:40 PM »
ask yourself a  question   do your tyres wear evenly? if they do why change the camber because it just means your tyres will wear unevenly. if you lower the car the camber will alter because of the lower spring and struts.so if you  mind wearing your rubber out rapidly don,t bother.
phreak97
  • Niki!
« Reply #2 on: March 11, 2008, 11:32:16 AM »
how on earth do the wheels wear evenly when theyre so sloped like that?
phreak97
« Reply #3 on: March 13, 2008, 09:34:49 AM »
because when you drive the car the camber balances out , i do believe.if i am wrong then forgive me . what does the car look like when it is weighed down with passengers or just driver?
« Reply #4 on: March 13, 2008, 09:37:25 AM »
its all to do with suspension geometry....do you reverse your car to its sitting place? if so the wheels will take on more pos camber,becaase the rear toes in,on the road with persons on board the wheels go fairly neutral..........your front wheels point inwards (toe in)too did you know that?..............tigers takin there toll here.....i think thats right eh mick?  :wink:
phreak97
  • Niki!
« Reply #5 on: March 13, 2008, 03:10:26 PM »
i dont think my fronts do.. and if they do it isnt nearly as much as the rear ones..  i dont think the rear flattens out when someone sits in it 9and i dont reverse into my driveway).. i guess i can see how the wheels might flatten out when driving, (if the rear wheels toe a little outwards at the front the road would pull the tyres outwards and in turn upwards, straightening them out and i guess lowering the rear when moving for some reason..) but why do it like that when every other car ever made seems to have a neutral camber when stationary without any trouble?
and wouldnt the default camber make cornering more dangerous? i've been round a few corners which felt like the tire was pushed a fair way in under the car... it doesnt feel particularly good in any respect. i guess youre meant to drive like a granny in a little 126?
they must have failed at the tame driving aspect.. i find mine just begs to be driven wildly, so much more than any of my other cars.. the 126 is just the ultimate fun car.
phreak97
« Reply #6 on: March 14, 2008, 12:16:16 PM »
well triumph spitfires and heralds had the same,so do fiat 850/600 etc...
if you wana chuck it around,fit reverse eye front spring an cut a coil an a bit from the back end....then the car will hit bumpstop on hard cornering and reduce tuckin....mine was like that anyway,it even was wheelspinning at the last stages of tune....
« Reply #7 on: March 14, 2008, 01:14:21 PM »
I used to have a few triumph vitteses and they suffered from the negative camber affect on the rear which made it handle like a pig!
There was a camber compensator mod details here
http://members.cox.net/spitlist/camber3d.pdf
Perhaps a similar device could be made for the 126? :shock:
phreak97
  • Niki!
« Reply #8 on: March 23, 2008, 02:59:01 PM »
i checked my tires, and they are worn more on the outside:/
phreak97
