Author Topic: gear box  (Read 3202 times)
joda
gear box
« on: March 04, 2008, 08:12:16 PM »
HELP!!
 few days ago my bis was maing a funny noise in first gear, like a whining
 then it started spitting it out of first year when driving away
 now it wont move in first gear, its like it wont select in,
 also reverse has done it few time also
 what can it be?
126Bis
gear box
« Reply #1 on: March 05, 2008, 05:47:16 PM »
sounds like you've stripped the 1st gear. this happened to me and is a common problem cos the 1st gear has no sycromesh so damage occurs easily, theres no way around it, out with that engine! :shock:
gear box
« Reply #2 on: March 05, 2008, 06:01:15 PM »
did you know there is no syncromesh on 1st and reverse?? you cant just throw it into gear like a normal car... crunchy...
gear box
« Reply #3 on: March 05, 2008, 07:48:50 PM »
LOL, ive been carefull with my first just for this reason :wink:
joda
gear box
« Reply #4 on: March 05, 2008, 10:34:12 PM »
so what now?  new gear box? or can i just replace the gear? whats easiest
126Bis
gear box
« Reply #5 on: March 06, 2008, 10:47:33 PM »
yes it can be done, but it involves taking the gearbox apart and replacing the " top shaft". if you look at the box at the top you will see a black cover. remove that and you will see it, and its a long shaft that has the 1st gear and the reverse gear on it. its that, that needs replacing and they cost.........wait for it..... about £100
gear box
« Reply #6 on: March 07, 2008, 12:00:16 AM »
i think getting an used or restored gearbox would be cheaper and easier than buying and installing just the shaft...
joda
gear box
« Reply #7 on: March 08, 2008, 11:04:19 AM »
there is a polih air cooled 126 in my local breakers yard, will this gearbox fit ok, read elswhere on here you change the bell houseing, that all?
126Bis
gear box
« Reply #8 on: March 08, 2008, 04:25:31 PM »
think so...  :wink:
lilp4130
gear box
« Reply #9 on: March 26, 2008, 11:26:25 PM »
is this true/possible??
i feel enthusiasm surging back into me!can i simply fit an a/c bellhousing to my bis box?this would solve a huge problem for me! :eek:
it's harder than it looks!
lilp4130
gear box
« Reply #11 on: March 27, 2008, 09:26:21 AM »
if you want to connect a bis box to an aircooled engine swap the bellhousing, if you wish to fit a aircooled box to a bis swap the bellhousing . bis gears are longer than aircooled so you will have reduced top speed if fitting aircooled box to a bis. if you wish to fit a 126 bis or aircooled box to a 1 litre engine (or 1.1 or 1.2 ) you must use a aircooled bell housing other wise you must design and fabricate your own mateing plate , the ones you can buy are to be used with the aircooled bellhousing .
lilp4130
gear box
« Reply #12 on: March 27, 2008, 11:10:16 AM »
fantastic! thanks bis13!!
i was having trouble getting a bis plate made up,i spent hours making a template but couldnt get someone to cast it for me!
after buying two a/c adaptor plates only to find they wouldnt fit and the countless other walls i've run up against during this build
i'd just got pissed off and put it on the long finger to work on my scooters,
but i now feel the bug coming back!
 :D  paddy
