Author Topic: Front wings are they the same for a Bis as an AIrcooled?  (Read 2499 times)
finlay
« on: February 29, 2008, 05:28:08 PM »
Just going to buy two new front wings but want to make sure that a 79 car wing will fir my 87 bis?
thanks
« Reply #1 on: February 29, 2008, 06:05:49 PM »
they may well fit but they are different, the bis has a more flared arch and also has two mounting holes at the bottom front corner for the plasic bumper to screw onto, its a good question as i am in need of 2 new ones myself and can only seem to source air cooled ones so if anyone has fitted air cooled ones to a bis then let us know! :D
« Reply #2 on: February 29, 2008, 08:04:19 PM »
I quote this from a web page timeline:
"Dec 1984
 Body shape altered slightly to comply with European safety legislation"
This seems to be the last alteration of the design (pre el-elx)so all 1984+
arches should fit the bis, earlier models might not...
(this is all in theory, i dont have first hand exp.)
« Reply #3 on: March 01, 2008, 07:16:07 AM »
i was led to believe that the aircooled wing has a smaller amount of metal than the bis near the rear of the panel near the doors whether this is true i dont know, however if you buy these wings you can always use them to patch up the original bis wings if you cut them up
finlay
« Reply #4 on: March 01, 2008, 10:41:45 AM »
Thanks guys, cant seem to find Bis wings but Beevers have the air cooled ones for £17 each. I dont need the trim holes - going to do away with them on the wings and doors and go for the 126gt2 "works" look! Its actually the front of the wing thats rotten so maybe buy an aircooled one and cut it up to get the metal.
Alternatively can Anyone suggest a source for genuine bis wings please?
« Reply #5 on: March 01, 2008, 09:30:05 PM »
i think the same place that sells rocking horse pooo!!!! :D
« Reply #6 on: March 01, 2008, 09:49:54 PM »
http://fiatclassic.com/
They have bis wings (front-45€ rear-137€)
« Reply #7 on: March 01, 2008, 10:11:34 PM »
they state that the wing fits all mks of 126 , just be carefull and confirm they do fit before you purchase them. good searching cro bis bloke!!
« Reply #8 on: March 01, 2008, 11:09:26 PM »
I saw that too, they have a aircooled engine cover under BIS so be carefull.... :???:
The names Gordan, and THX  :wink:
Tomasz
« Reply #9 on: March 02, 2008, 11:20:40 AM »
eary aircooleds have less flare on the arch than later ones for sure.  I found this out after ordering a front wing which turned out to be wrong.
« Reply #10 on: March 06, 2008, 02:39:09 PM »
aircooled wings will not fit a bis,the flare of the bis inner wing stops the aircooled wing from fitting to the front panel
« Reply #11 on: March 06, 2008, 10:38:12 PM »
can it be cut back?
« Reply #12 on: March 07, 2008, 07:41:23 AM »
i guess so gadge...i think thats all that stops them goin on,the diff holes etc are another story tho
