Author Topic: Melting fuse  (Read 4483 times)
Melting fuse
« on: February 13, 2008, 10:29:37 PM »
A week ago I noticed that one of my fuses (the cooling radiator fan one) had melted the plastic parts but it hadnt burnt, upon reading the manual i found out it was a wrong amperage fuse, and installed a new and right one (30A), but upon inspection I found out it had started melting aswell...
I just dont know what could be causing it to melt and not to burn out...
If anyone has the slightest idea what it could be plaese let me know...
Melting fuse
« Reply #1 on: February 13, 2008, 10:39:24 PM »
nice to hear the austin powers line, this 126 lark isnt going your way is it.. lol
Melting fuse
« Reply #2 on: February 13, 2008, 10:42:56 PM »
well I cant say I didnt expect problems.....
But throw me a freakin bone here people!!!
Melting fuse
« Reply #3 on: February 13, 2008, 10:52:48 PM »
mini me... stop humping the lazor!!!
Melting fuse
« Reply #4 on: February 14, 2008, 08:24:17 PM »
Mine does the same and it eventually blows.  I have searched the loom and even replaced the two stage switch but it still melts!  So I don't know but if you work it out please let me know.
Melting fuse
« Reply #5 on: February 14, 2008, 08:32:38 PM »
Sounds like a relay wired up incorrectly?
Melting fuse
« Reply #6 on: February 14, 2008, 10:22:55 PM »
And which relay would that be, I newer touched the electronics of the car, just those few wires that need to be removed when taking out the engine and im pretty sure i put them back correctly...
I mean, its not that big of a problem replacing a fuse every now and then, but im afraid it might do more damage to the wiring.... :???:
Melting fuse
« Reply #7 on: February 14, 2008, 11:45:00 PM »
Try replacing the radiator cooling fan relay. I am just going off the wiring diagram, seems the most logical thing that can cause this kind of problem...I may be wrong?  :smt017
Melting fuse
« Reply #8 on: February 15, 2008, 10:07:52 AM »
This may well br the cause!  When Ifirst bought my Bis the lighting relay was wired up incorrectly and the lights were dim and kept flattenning the battery, never thought to check the relay for the fan!
Melting fuse
« Reply #9 on: February 15, 2008, 05:36:03 PM »
Alrighty then, Ill check it out....
THX Chris :wink:
Melting fuse
« Reply #10 on: February 15, 2008, 10:40:56 PM »
I searched my manual and found the location of the relay, ill try to get a new one but i doubt this will be easy....
Melting fuse
« Reply #11 on: February 16, 2008, 04:30:37 PM »
I dont know if this is of help, when I got my BIS the rear wiper motor was seized (I didnt know this at the time) and every time i attempted to use if the motor seizure would cause the fuse to blow .. the fuse seemingly was also being used for the cooling fan the last time it blew on a hot day it took my head gasket out and caused an engine rebuild ...
Im not sure if this is how it should be wired up but up shot is might be worth checking if things are getting hot when using the rear wiper as this might be causing it.....
cheers
stuey.
Melting fuse
« Reply #12 on: February 16, 2008, 11:13:00 PM »
Stuey, thanx for ur reply... the thing is, my bis doesnt have a rear wiper, or heated rear window, or rear fog light, or opening rear windows, or rear seat belts for that matter  :x (but whos complaining :wink: )
It must have been a cheaper wersion, as are 90% of bis models here :sad:
Melting fuse
« Reply #13 on: February 16, 2008, 11:33:06 PM »
jeez I must have the deluxe version.... hope you get it fixed dude  :wink:
Melting fuse
« Reply #14 on: February 16, 2008, 11:49:15 PM »
Me too, i even have head rests!!! BUT NO FAG LIGHTER!!! i mean how much money were FSM trying to save with no fag lighter!!   :x
