Author Topic: SUMP  (Read 1435 times)
jon.hunt
SUMP
« on: February 06, 2008, 09:17:48 AM »
Hi All
          Wondering is it an Easy Job to change the Sump on an Air Cooler whilst the Engine is in the Car Please.
                                                          Jon.
SUMP
« Reply #1 on: February 06, 2008, 12:30:01 PM »
It is very easy, but expect to get a little messy.
Drain all the oil first (obviously!)
Then there are a number of small bolts that hold the sump on to the crank case, just undo all these and it should just pull off. Whilst it is off, you may as well change the gasket and give the underside of the crank + oil collector a nice clean. Then just reverse the process to put the new one back on.
The only trouble you may face are some awkward to reach bolts on the gearbox side, but you'll be fine so long as you have a reasonably compact socket set.
