Author Topic: brake disc mounts  (Read 3789 times)
brake disc mounts
« Reply #1 on: February 04, 2008, 08:06:22 PM »
Hi Mate those are the same ones i bought direct from TRS although i hav'nt got round to fitting them yet, as far as i'm aware all 126 use the same front stub axel, so should fit with no problems.
They are alot cheaper from TRS but when i bought them i had to send the money through Ebookers so i had to open an account, pitty they don't have a paypal account they could do alot more business.
brake disc mounts
« Reply #2 on: February 04, 2008, 08:24:23 PM »
purchased  :D
apart from calipers, pads and discs what other bits do you need to buy,
also does it alter the wheels base of the car at ... my wheels stick out a bit as it is :(
brake disc mounts
« Reply #3 on: February 04, 2008, 08:51:33 PM »
You will need the caliper carriers as well, don't know if there is any difference in the track hav'nt got that far yet (waiting till it gets warmer)
best to go to the scrappers you can get all the bolts and bits cause the new parts cost a fortune.
brake disc mounts
« Reply #4 on: February 04, 2008, 09:01:19 PM »
thanks for the info pedro one more question do you have alter the wheel bearings?
brake disc mounts
« Reply #5 on: February 04, 2008, 09:09:51 PM »
No just use the original hubs that the drum sits on.
brake disc mounts
« Reply #6 on: February 05, 2008, 09:55:31 AM »
I'm not sure if it is different or not for the cinq calipers, but I needed at least a 10mm spacer on the end of this kit to allow the wheel to clear the caliper.
I do have x/19 / Polonez calipers instead though, so they may be larger.
nitro_trs
    • http://www.trs-racing.pl
brake disc mounts
« Reply #7 on: February 10, 2008, 11:47:25 PM »
Quote from: "pedro126"
Hello. I finaly have a paypal account!  :D
TRS SWAP CENTER  www.trs-racing.pl
brake disc mounts
« Reply #8 on: February 11, 2008, 05:38:59 PM »
Quote from: "nitro_trs"
welcome TRS :D how about a thread showing your products with some prices? It would nice to see you stuff!!
nitro_trs
brake disc mounts
« Reply #9 on: February 12, 2008, 10:53:09 PM »
I will do it, but I don't have time right now :roll:
brake disc mounts
« Reply #10 on: February 13, 2008, 04:43:00 PM »
no bother dude really like your brake mounts they are qual;ity by the way :D
nitro_trs
brake disc mounts
« Reply #11 on: April 14, 2008, 06:57:19 AM »
Thank you :oops:
